Rheem Hotwater heater, econet?
I’m very new to HA but not Home Automation in general. I have a Rheem econet enabled water heater. I added the econet support to my Home Assistant (Hassio) on a Raspberry Pi 3B+ and it worked fairly reliably. However, that support was through the Wink software hub. Now, I’ve tried to enable econet support to communicate with Rheem Econet directly and I’ve followed all the directions to enable it using the water_heater component and it’s not working. The entity appears as “unavailable” and the log reads as follows…
Authentication request failed. Please check credentials: 500
Token expired
Both the iOS and Android apps work normally logging onto and operating econet WRT my water heater but, for some reason, when I enter that same info into my configuration.yaml file, it never successfully logs on.
Has Rheem altered something in their app to disable the function of the water_heater component in HA? Or, am I missing something?
Thanks.
