RIELLO PV RS 3.0 solar inverter integration
Hi everyone! :wave:t2:
I’ve been trying for some time to integrate the inverter of my photovoltaic system, a Riello PV RS 3.0 inverter, which has native WiFi connectivity.
The instruction manual shows the following indications:
The PV inverters are equipped with integrated dual channel Wi-Fi connection. Using the dedicated “RS Connect” app it is possible to establish a local connection to the system using the inverter as an access point (channel 1) for pre-configuration activities (such as self-test and communication parameters setting), instant and periodic analysis and production measurements. The second Wi-Fi channel allows connection with your home router to send information to the Riello Solartech cloud which will be displayed on the “RS Monitoring” supervision portal.
For installation and configuration settings, use the dedicated RS Connect app.
To monitor the energy production, use the RS Connect app or register in Riello RS Monitoring cloud portal: www.riello-rsmonitoring.com.
Is there any “tool” to add this monitoring to Home Assistant? Thank you all!
