Hi guys,
I’m trying to create a couple of energy meter devices using the Riemann sum helpers. I’ve created a couple of simple template sensors like this:
- unique_id: "Utelamper effekt"
device_class: power
unit_of_measurement: W
state: >
{% if states('input_boolean.utelys_indikator') == "on" %}
{{90}}
{% else %}
{{15}}
{% endif %}
- unique_id: "Kjøleskap effekt"
device_class: power
state: 15
Then I’ve set up the Riemann sum devices in the UI. Here you can see the result.
With the “Utelamper”-one I’ve tried setting the state of the sensor device directly through the UI, and then the Riemann sum works. It seems like it cant interpret the number as a number?
Thanks!
