Riemann sum integral with input_boolean condition
I want to obtain the energy consumed from a power sensor. I know I can get it with the Riemann Sum Integral, but I want to get the sum only when an input_boolean has a given value (on or off).
To give some context, I have a tariff with two time periods, one cheap (valley) period and another expensive (peak) period. I’d like to get the energy consumed (and also the cost) of each period. Latter on, I’d get the energy (cost) of electricy in each period for today, yesterday, … with the new Statistic Card.
This information is not given in the energy panel, although it can be taken it into account there to get the total cost of energy.
I’ve solved this creating template sensors with power consumption in cheap and expensive periods by means of:
	  sensors:
		piso_calefaccion_potencia_barato:
		  friendly_name: Piso calefacción potencia barato
		  device_class: power
		  unit_of_measurement: W
		  value_template: >
			{%  if states('input_boolean.piso_horario_barato') == 'on' %}
			{{ states('sensor.shelly_piso_channel_1_power') }}
			{% else %}
			{{0 | float }}
			{% endif %}
		piso_calefaccion_potencia_caro:
		  friendly_name: Piso calefaccion potencia caro
		  device_class: power
		  value_template: >
			{%  if states('input_boolean.piso_horario_barato') == 'off' %}
			{% else %}
			{{0 | float }}
			{% endif %}
where input_boolean.piso_horario_barato is on for cheap period and off for expensive one.
After that, I’ve created integration sensor helpers, which can be loaded into energy panel.
In this way, the energy panel will split energy consumption and costs among cheap and expesive periods.
