I’m using Aurora Lighting AU-A1ZBDSS ZigBee UK sockets, they don’t measure energy consumption but they do measure real time power consumption in watts. I’m using Riemann sum integral sensor for each socket to track energy usage over time. It’s been working well for a while but I’m getting odd positive readings from some of them and I have no idea why. Screenshots below:
Did you restart HA at the same time you observed the values reset to 0? If so, that’s expected behavior of the helper. At least mine do that and it does not affect my energy statistics.
It’s possible it coincides with a restart on occasion, but it happens without a restart also and it only affects some of them, as you can see I have many that aren’t exhibiting the same behaviour
I just upgraded from 5.2 to 6.1 hoping this issue is resolved; however I see that the commit is only in the dev branch at the moment. Can you confirm you’re still seeing this issue? Thanks.
