Rika automation
I m using the rika firenet plugin.
In this plugin i can get the status of the stove (standby, running, burn_off, etc.)
When the status is on running, i would like to make an automation which will switch on a fan.
When the status is on standby, i would like to make an automation which will switch off the fan.
The problem is that it doesn’t work. Do you have any ideas why ?
Thank a lot
Tony
Hi.
Remove the “from” part in the trigger, there are intermediate states between standby and running, the status never goes directly from one to the other
Sharing images of the automation editor is not very helpful. You should share copied text from the yaml button and format it so it can be read.
When you signed up for the forum and read the FAQ, you perhaps missed the section on asking questions. Here’s a link to that on how to format code to best get help.
How to help us help you - or How to ask a good question.
