I am running hassio in FreeNAS and have been recently working to get all of my integrations working. I have a Ring doorbell and a Ring alarm system with two factor auth enabled on my Ring account. I was able to connect to HA to Ring using the native integration but that only works for my doorbell and not the alarm portion. I read about using MQTT and https://github.com/tsightler/ring-alarm-mqtt to get it to integrate but the ring alarm hassio integration add on has not been updated in months and does not support the 2FA login. Whenever I start the add on it just sends the auth code to my phone but there is nowhere to enter it in the addon or in HA.
So my question is, has anyone been able to get Ring alarm to work in HA since 2FA has been enabled and if so, how?
So you are saying 0.104 Ring integration should be able to see the alarm as well as the doorbell? I am able to get the doorbell entities to show but not the alarm entities. I’ll check my config to see if there is a manual entry messing with it.
