I’m trying to hook my Ring alarm system into Hass.io but am having no luck. After finally getting my MQTT Broker up and running, I tried installing the add-on found at https://github.com/rs1932/ring-alarm-hassio-addon based on work by @tsightler. I configured it per the instructions, start it and the add-on log suggest that it starts running. However, none of my the devices in my Ring security system show up and after a minute or so, the add-on stops running and the log contains an entry that reads “2019-08-21T23:59:08.244Z ring-alarm-mqtt Exit code: 1”.
Any idea what may be going wrong?
