Ring Alarm keypad and door contacts in Home assistant. Need an expert please
I have the Ring Alarm all setup with Keypad and door contacts it uses Zwave Plus.
I then purchased the Aeotec Zwave 7 stick thinking I can use that to add these into Home assistant. I used smart start to scan the QR code and the devices are all added as Provisioned. I’m not sure what that means and if it’s even possible to bring these into home assistant as entities?
Has anyone got any experience of this would appreciate some guidance.
You will need to use either ZWave JS or OpenZWave to integrate them into HA.
I would use ZWave JS, as OpenZWave is deprecated.
Yeah I setup Zwave JS sorry should have clarified. But when I scan the QR code it only adds it as a provisioned device. So stuck at this point as to how to actually include them as entities.
doesn’t matter I instead used MQTT and have got all my devices into HA
