So there has been a lot of issues with the (great) Ring integration with HA caused by ring doing lots of changes to their public API. Whilst this gets sorted out, I thought I would get ring alerts from IFTTT working and join them together with the alerts from the ring integration to ensure reliable alerts.
Workflow looks like this:
Ring Motion/Ding -> IFTTT -> Webhook to HA -> Update input_boolean -> Updates binary_sensor
The binary sensor combines alerts from the ring integration with IFTTT so that ensures a belt and braces approach to getting alerts. So, here are all the integration steps.
- Setup an IFTTT Account
- Add Ring and Webhook services
- Ensure your HA instance is publicly accessible via HTTPS
- Enable Webhook service on HA Integrations page (rember to copy the URL)
- Create two IFTTT ring/webhook events for ring and motion and ensure the method, content type an body are set like this:
Data for motion event
Method: POST
Content Type: application/json
Body : { "action": "call_service", "service": "script.turn_on", "entity_id":"script.ifttt_front_door_motion" }
Data for ring event
Method: POST
Body : { "action": "call_service", "service": "script.turn_on", "entity_id":"script.ifttt_front_door_ring" }
- Add Webhook automation to automation.yaml
### Webhook handler
- id: ifttt-webhook
alias: "IFTTT Webhook events"
initial_state: true
platform: event
event_type: ifttt_webhook_received
event_data:
action: 'call_service'
service_template: '{{ trigger.event.data.service }}'
data_template:
entity_id: '{{ trigger.event.data.entity_id }}'
- Add Input booleans, binary sensors and a couple of timers to configuration.yaml (my integrated ring sensors are called binary_sensor.front_door_motion and binary_sensor.front_door_ding, yours may be different)
# Input Booleans
# IFTTT ring motion
input_boolean:
ifttt_front_door_motion:
name: IFTTT Front Door Motion
initial: off
icon: mdi:run
# IFTTT ring ding
ifttt_front_door_ding:
name: IFTTT Front Door Ding
initial: off
icon: mdi:bell-ring-outline
# Binary Sensors
binary_sensor:
# Sensors for combinbing IFTTT and Ring sensor events
sensors:
combined_front_door_motion:
friendly_name: "Combined Front Door Motion"
device_class: motion
value_template: >-
{{ is_state('input_boolean.ifttt_front_door_motion', 'on') or is_state('binary_sensor.front_door_motion', 'on') }}
combined_front_door_ding:
friendly_name: "Combined Front Door Ding"
device_class: occupancy
value_template: >-
{{ is_state('input_boolean.ifttt_front_door_ding', 'on') or is_state('binary_sensor.front_door_ding', 'on') }}
# Timers for the motion and ding sensors
timer:
duration: '00:01:00'
icon: mdi:timer
icon: mdi:timer
- Add scripts which are called by the webhoook events to scripts.yaml
### IFTTT Webhook handler scripts
sequence:
- service: timer.start
entity_id: timer.ifttt_front_door_motion
entity_id: input_boolean.ifttt_front_door_motion
sequence:
entity_id: timer.ifttt_front_door_ding
entity_id: input_boolean.ifttt_front_door_ding
- Automations for resetting the input_booleans when the timers finish
### Front Door Bell Notifications & Controls
- id: ifttt-front-door-motion-timer-finish
alias: "IFTTT Front Door Motion Timer Finish"
initial_state: true
platform: event
event_type: timer.finished
event_data:
- service: input_boolean.turn_off
- id: ifttt-front-door-ding-timer-finish
alias: "IFTTT Front Door Ding Timer Finish"
initial_state: true
platform: event
event_data:
- Restart and your done
You will how have two new binary sensors:
binary_sensor.combined_front_door_ding
binary_sensor.combined_front_door_motion
Which combine events from IFTTT and the native Ring integration. You can control the duration of the IFTTT ding and motion events by changing the timers. (NOTE: Previously the Ring sensors would trigger for 2 mins before clearing. This is no longer the case, and the motion sensor can get cleared after only a few seconds)
Hopefully the Ring integration will become more reliable as the API becomes stable, but once setup, this ensures two separate pathways to get ring events.
