I have an intercom that opens the neighborhood door for the 200 neighbors (everyone has their own internal unit, to control one external door), on my intercom I have fitted a ring intercom, so far so good.
I can from home assistant open the door when someone calls, that’s good,
The thing is that I want to automatically open the door after someone calls at the bell, on specific days of the week at specific times
For example
Cleaning service comes on Mondays at 12 am and does have the internal key to access, but not the external door.
Program that every call between 11:45 and 12:05 on Mondays gets automatically opened (after a x seconds buffer time).
Can I get some help with this blueprint, so far GPT not that good! Can’t find one already made, I thought this was a common use case, wasn’t expecting it to not be already done by someone.
Thanks!
blueprint:
name: Desbloqueo Automático de Puerta con Ring Intercom
description: >
Automatiza el desbloqueo de la puerta mediante Ring Intercom basado en eventos, con restricciones de tiempo y día.
domain: automation
input:
ring_event:
name: Nombre del Evento de Ring
description: "Nombre del evento generado por Ring Intercom para llamadas entrantes."
default: "ring_event"
selector:
text: {}
door_unlock_button:
name: Botón de Desbloqueo de Puerta
description: "La entidad del botón que desbloquea la puerta."
selector:
entity:
domain: button
days_of_week:
name: Días de la Semana
description: "Selecciona los días en los que esta automatización estará activa."
default:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
selector:
select:
mode: list
multiple: true
options:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
start_time:
name: Hora de Inicio
description: "La hora de inicio para la automatización."
selector:
time: {}
end_time:
name: Hora de Fin
description: "La hora de fin para la automatización."
selector:
time: {}
delay_before_unlock:
name: Retraso Antes de Desbloquear
description: "Tiempo en segundos antes de desbloquear la puerta tras recibir el evento."
default: 5
selector:
number:
min: 0
max: 60
unit_of_measurement: seconds
mode: slider
- platform: event
event_type: !input ring_event
condition:
- condition: time
after: !input start_time
before: !input end_time
weekday: !input days_of_week
- delay:
seconds: !input delay_before_unlock
- service: button.press
entity_id: !input door_unlock_button
mode: single
Are you testing this using run in the editor or with a real physical event?
I have ring installed for my doorbells. I do not see this listed in developer under events. Are you sure that is really an event? (or are you putting something else in there?)
I don’t really understand events coming from witches and binary sensors this is a new thing for me, Also I am having a problem with the automation tuning on any ring event, (there is an event ring creates when ringing, and when opening and it gets into a loop, also there is an event I think after a minute when “las opened” and “last ring”)
blueprint:
description: >
domain: automation
input:
ring_event_entity:
name: Entidad del Telefonillo
description: "Selecciona la entidad que genera el evento cuando se llama al telefonillo."
selector:
entity:
filter:
- domain: event
ring_event:
name: Tipo de Evento
description: "Tipo de evento que debe detectar el telefonillo (por ejemplo: 'ding')."
default: "ding"
selector:
text: {}
door_unlock_button:
description: "Selecciona el botón que desbloquea la puerta."
selector:
entity:
filter:
- domain: button
days_of_week:
default:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
selector:
select:
mode: list
multiple: true
options:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
start_time:
default: "00:00:00"
selector:
time: {}
end_time:
name: Hora de Fin
default: "23:59:59"
selector:
time: {}
default: 2
selector:
number:
min: 0
max: 10
- trigger: event
event_type: state_changed
event_data:
entity_id: !input ring_event_entity
condition:
- condition: state
attribute: event_type
state: !input ring_event
- condition: time
- delay:
- action: button.press
mode: single
