Ring Chime entities dont show in automations
Hi I have ring Chime installed, there are four entities with it including siren, I used this one in a previous install and it worked fine. If I activate the toggle in this install ring chime goes off, excellent.
However that siren entity is not available as a call order service under automations, so I cannot use it.
Can someone explain how I can get it recognised? I know it was in a previous install because I have screen grabs of it as a call order service, its just not available in the list. If I manually enter it, the config complains there is no such entity (there is I literally just activated it!)
