Hi All
Im new to this forum (however im not new to home automation, especially being an IT Consultant)
However, i am running into a couple of issues. Just to give you a little bit of back ground, we are a large family, however my partner and 2 of our children are unfortunately hard of hearing and require hearing aids during the day etc.
Because of this i am trying to set up some automation to help them, but im struggling with a couple of things. I will list what i am trying to achieve first, and then where i have got up to.
Ring Door Bell -
When someone presses the doorbell - i would like a group of Philips Hue bulbs to flash blue for around 15 seconds. (This bit is easy, its the next bit im struggling with)
Once the 15 seconds are over, if the light was already off, i would like it to be left off. If the light is turned on, i want it to stay on, but return to the colour it was either on, or as a compromise, return back to White.
I have tried doing this via scenes etc already, but its either leaving the light on, in the colour blue, or turning the light off after the scene has run. (I am looking into the scripting to see if this is even possible.
Nest Protect -
Now i know this isnt available yet, however i am planning this in now to try and figure it out, if i can fix the above, i know ill be able to get this to work. The idea is, is the smoke alarm goes off, it flashes Red, and carbon monoxide, it should be yellow.
If anyone could help at all, id be extremely grateful, it may be a script, or it might not even be possible, but it would be great if i could even get 90% there.
Many thanks
Rob
List item
