Hi all, when I use safari to preview my Ring Doorbell Camera via NabuCasa I only see a new window with a ‘?’ in the middle. When I open the same preview while logging in via the internal IP address, all is fine. Anyone else experiencing the same?
Shall I report an issue with the Ring developers or the Nabu Casa team?
If you can login via ring website and access cameras within the ring app then ring will not support it. Then it would be an issue with home assistant or nabu casa. You may want to look at the forums regarding home assistant and ring live view for further setup instructions. Hope this helps.
I even opened an issue for it, because Nabu Casa is a payed solution. But nobody seems to care. So I think it’s my coice, leaving as is of leaving Nabu Casa.
