ring doorbell pro has snapshot capture feature that takes snapshot periodically, is there a way do download snapshot for a time range to local disk?
is it possible to use the doorbell pro camera to take a snapshot from node-red? I tried to use snapshot action similar to ffmpeg camera, but it seems give me a picture of last motion detection picture.
@henry8866 were you able to resolve this issue?. I’ve been trying to do exactly what you mentioned in your post, using Ring’s motion sensor as the trigger for a camera snapshot.
It appears based on observation, that the snapshot is effectively the first frame of the last stream recorded and not actually a current realtime snapshot as the service ‘camera.snapshot’ would appear to imply.
