@broesie Thanks. Currently the last_activity sensor has an attribute called ‘created_at’ which will give you the current time and date. These are the attributes from my last_activity sensor:
Dumb question. I jumped in this early and since upgraded to HA 0.40.0 which has ring incorporated. Am I using the Ring version from Github still and if so how do I remove it.
Better version of the same question.
Where is Ring installed in 0.40.0 and where was it installed manually before? Do I just remove the ring_doorbell directory in /deps?
I can’t get the binary sensors installed as noted in previous posts.
Let me add a little more here. I’m all fouled up with ring now. I installed the new sensor and binary sensor in custom components and now getting the following:
17-03-13 10:26:01 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.ring]: value is not allowed @ data['monitored_conditions'][2]. Got 'motion'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.ring/
I deleted the previous ring.py which seems to be where the problem started. Ultimate goal is to get ring as a binary sensor. And also pretty sure I have a previous version installed in deps but now scared to delete it too.
Yes, I know, but then we have to split the data. So, it would be great to see some several seperated sensors.
And if it’s not too much asked, I would be great to have control how it’s written, in some countries it is yyyy-mm-dd, in other countries it is dd-mm-yyyy… That would be also a nice option… anyway, keep up the good work!
@tchellomello I’m seeing a lot of these warnings in my log:
17-03-14 20:41:12 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:42:12 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:42:18 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:50:27 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:50:50 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:51:52 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:53:51 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
17-03-14 20:57:07 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:05
This is just a small portion, it seems to be ongoing still.
@syphernl interesting… how about to change the frequency to 15 seconds to see if the messages goes away. I think this is happening because we are calling the sensor every 5 seconds.
It went away after restarting HA, seems to be working fine afterwards. It happened right after someone rang the doorbell, but the binary sensor didn’t pickup on that since no automations were triggered.
I just bought a ring and second thing I did was add this component, so first off, a big thank you for your hard work on this!
Now for a few questions:
1 - Since 0.40.0 is the first time I’ve loaded this component, I noticed some strange behaviour. I am unable to restart Home Assistant by using the call service. I get this error:
03-16 07:05:25 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.sensor.ring. Make sure all dependencies are installed
However, if I shut down HA from the command line, it does restart normally and Ring does show up with the 3 sensors.
2- Is the binary_sensor available in 0.40 or do I have to install the latest custom component?
Thanks @tchellomello. I was thinking the camera image could be useful for the Microsoft face detect/identity components. Setting scenes or custom events when recognizing faces. Would love to give those components a try with Ring!
Be advised that if you don’t have a hardwired Ring, simply activating LiveView (not even USING it, just activating it) even in battery saver mode is going to take a chunk out of your battery life.
I charged mine to full a week or so ago and I am already down to 77% today.
Wow! That really kills the battery. I have the hardwired Ring Pro, but I guess the same principle would be for the stick-up cams since they are battery powered.
17-03-19 20:01:53 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while update entity from ring in binary_sensor
File "/srv/hass/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 428, in _update_entity_states
yield from update_coro
File "/srv/hass/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 207, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/hass/.homeassistant/custom_components/binary_sensor/ring.py", line 129, in update
self._data.check_alerts(cache=self._cache)
File "/home/hass/.homeassistant/deps/ring_doorbell/__init__.py", line 375, in check_alerts
resp = self._ring.query(url)[0]
TypeError: 'NoneType' object is not subscriptable
It looks like the Binary sensor may cause some issues with accounts. Over the past week I had to re-login to the Ring app on my phone which never happened before I started using the component.
In order to work around that I have created a sub-account with access to the Ring but unfortunately after configuring this in HA the Ring component disappears from the webinterface even though it is possible to use the Python library with these credentials.
The reason the Python library works is because it has recently been updated to fix showing devices from “shared accounts”, the HA component hasn’t been updated yet though.
