Ring: Error: 401 Client Error: Unauthorized for url
Yep, ring updated their API when they added 2FA.
+1 here - just a reboot on 103.0 and Ring gone :frowning:
There is a potential fix in the works, as discussed in the link arsaboo shared above.
they send me an reply on the email, home assistant needs to partner up with ring to get this working again i hope the other PR is going to work.
why contact Ring. they don’t want us to not use Ring app.
Yup, same here after a reboot.
As if I needed another reason to look at a different doorbell solution…
I moved to Halo ONE (gen2).
Sadly there isn’t a good alternative to the driveway/floodlight camera.
Hello @firstof9 and everyone. There is a PR already submitted by @xernaj that will address the issue. You can follow it at https://github.com/tchellomello/python-ring-doorbell/pull/143
Have just updated my to 103.2 and ring is not working at all now
Getting the following notification
Error: 403 Client Error: Forbidden for url: https://api.ring.com/clients_api/session
You will need to restart hass after fixing.
Just ran the temporary fix in the open github issues:
All works fine for me now.
Same for me as soon as I updated to 0.103 so are we sure is not the new HA version that is the issue here?
2019-12-20 14:09:45 ERROR (SyncWorker_16) [homeassistant.components.ring] Unable to connect to Ring service: 403 Client Error: Forbidden for url: https://api.ring.com/clients_api/session
We are sure.
It is Ring. They have changed something. It is co-incidence that it broke with the new version of HA - mine broke with no update, just a HA reboot. If you follow the link I posted above, there is a temporary fix.
Well i’m not sure about that since it says:
& copying the contents of ring_doorbell to /srv/homeassistant/lib/python3.6/site-packages/ring_doorbell then removing the ring directory in custom_components & restarting HA
As i cannot find /srv/homeassistant/lib/python3.6/site-packages/ring_doorbell and I don’t have anything Ring in my custom components folder either.
I’d just sit tight for the fix to merge :wink:
Mine was in /srv/homeassistant/lib/python3.7/site-packages/ring_doorbell.
I will add I am running HA in a Python VirtEnv and not docker or HassIO.
I moved the existing files to a subfolder called ‘orig’ and then extracted the field to it, rebooted HA and Ring back :slight_smile:
No idea where the path is for Hassio, running it on a pi4. Anyone with a similar setup know the folder path?
If anyone has any update please share it… running Hassio on PI4
If you download this and drop it into custom_components should fix it: https://drive.google.com/file/d/1C41E7OlOUZLtXBHosV9U6HTlBWNN8Cxf/view?usp=sharing
Just did for me and I’m running hassio on a pi4
