Ring: Error: 401 Client Error: Unauthorized for url
Confirmed direct update via pip worked… Then noticed release 0.103.5 which is for this specifically. Also good.
I’m running latest HA container and worked fine. However it failed last night when I rebooted HA with error:
2020-01-10 07:21:47 ERROR (MainThread) [homeassistant.setup] Error during setup of component ring
    raise MissingTokenError(description="Missing access token parameter.")
oauthlib.oauth2.rfc6749.errors.MissingTokenError: (missing_token) Missing access token parameter.
2020-01-10 07:21:48 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform ring.sensor: Unable to set up component.
2020-01-10 07:21:48 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform ring.binary_sensor: Unable to set up component.
2020-01-10 07:21:48 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform ring.camera: Unable to set up component.
It seems a different issue, anyone one has similar? how to fix it?
Thanks!
So in 103.5 it worked, upgraded today to 103.6 and it failed. The error is as above:
  File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
    component.setup, hass, processed_config  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/ring/__init__.py", line 55, in setup
    ring = Ring(username=username, password=password, cache_file=cache)
  File "/usr/local/lib/python3.7/site-packages/ring_doorbell/__init__.py", line 62, in __init__
    self._process_cached_session()
  File "/usr/local/lib/python3.7/site-packages/ring_doorbell/__init__.py", line 91, in _process_cached_session
    req = self.query(url, raw=True)
  File "/usr/local/lib/python3.7/site-packages/ring_doorbell/__init__.py", line 198, in query
    'Bearer {}'.format(self._get_oauth_token())
  File "/usr/local/lib/python3.7/site-packages/ring_doorbell/__init__.py", line 111, in _get_oauth_token
    self.auth = oauth.refresh_tokens()
  File "/usr/local/lib/python3.7/site-packages/ring_doorbell/auth.py", line 59, in refresh_tokens
    token = self._oauth.refresh_token(OAuth.ENDPOINT)
  File "/usr/local/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py", line 446, in refresh_token
    self.token = self._client.parse_request_body_response(r.text, scope=self.scope)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 421, in parse_request_body_response
    self.token = parse_token_response(body, scope=scope)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 431, in parse_token_response
    validate_token_parameters(params)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 441, in validate_token_parameters
saw in another post there is a fix already, but it is github repo.
A temp fix is already in play.
Might be useful to keep the snip-it to grab master if you find yourself falling into the impatient category while it’s being ironed out.
Here’s my version in case it’s useful for others.
cd /tmp/
wget https://github.com/tchellomello/python-ring-doorbell/archive/master.zip
unzip master.zip
docker cp python-ring-doorbell-master/ring_doorbell homeassistant:/usr/local/lib/python3.7/site-packages/
docker restart homeassistant
If you want to try out other commits. (For HA, 0.103.5/0.103.6)
commit="3348afdaab74ca55f01018bf9e19e61a815738ee"
wget https://github.com/tchellomello/python-ring-doorbell/archive/$commit.zip
unzip $commit.zip
docker cp python-ring-doorbell-$commit/ring_doorbell homeassistant:/usr/local/lib/python3.7/site-packages/
To switch back to homeassistant’s version (reinstall via requirement of manifest)
docker exec -it homeassistant python3 -m pip uninstall --yes ring_doorbell
Or update to next HA version when available. (Best option)
which one is currently working? tried master.zip still error out.
Its not yet in the main stream
In your hassio/system
Join the beta channel
restart
You should see 104.0b3 as being available
So I upgraded to 104 and removed the stuff from my config. Multiple restarts but still no luck getting it set back up. I don’t have a pickle file.
[2020-01-16 13:40:55 ERROR (MainThread) [homeassistant.components.ring.config_flow] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/ring/config_flow.py", line 45, in async_step_user
    token = await validate_input(self.hass, user_input)
  File "/usr/src/homeassistant/homeassistant/components/ring/config_flow.py", line 22, in validate_input
    auth.fetch_token, data["username"], data["password"], data.get("2fa"),
  File "/usr/local/lib/python3.7/site-packages/ring_doorbell/auth.py", line 40, in fetch_token
    headers=headers,
  File "/usr/local/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py", line 244, in fetch_token
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 411, in parse_request_body_response
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 379, in parse_token_response
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 386, in validate_token_parameters
    raise_from_error(params.get('error'), params)
  File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/errors.py", line 415, in raise_from_error
    raise cls(**kwargs)
oauthlib.oauth2.rfc6749.errors.UnauthorizedClientError: (unauthorized_client) The client is not authorized to request a token using this method.
Hassio system:
arch	armv7l
dev	false
docker	true
hassio	true
os_name	Linux
python_version	3.7.6
timezone	Europe/London
version	0.104.0
virtualenv	false
Did you have it setup up as a custom component,
Did you download the ring doorbell library to your config folder ?
Is so to any of the above remove them
I have this same issue, did not do a custom component and did not load the library. This seems to me that there’s a refresh token somewhere that is being used but ring doesn’t like it. Need to reset the component to go through the original auth with no existing refresh token.
