So Ive got the Ring camera component installed as always, and it just will not work. I keep getting the errors: Error starting FFmpeg.
FFmpeg fails all args must be str or bytes
I installed FFmpeg, like it should be, and still get that. It was working for all of ten minutes before I had to restart HA for a config change, and then nada. And its down across both the old states ui and Lovelace. Now its just sitting at the typical gray image or “image not available”
Ubuntu 16.04 32bit Server on an Intel Atom board, for reference
