I too have the same issue, started happening about 2 weeks ago. I found that if you reload integration it gets updated for a while and then stucks again.
Mine looks like is updating but the automation I created is not working. How do you go about events in automation? Anyone can help? I need my speaker to play an announcement when the event of pressing the button happens. Thanks
I also have the same problem, I opened an issue in github but it’s exaclty what you all said. Meanwhile I will move to the mqtt one. it’s like events are not fired but if I reconfigure it all the past events are fired at that moment.
