Very good news
Looks like v.0.2.9 of the lib had been published here https://github.com/tchellomello/python-ring-doorbell/releases
Any guide as to how to build this into an existing HA server, or is it just just best to wait for an official release ? (I use Hassio on a Piā¦)
PS. Tried turning off protected mode on the SSH server plugin, full shutdown and restart of HA, connected via SSH and I still cannot see any of the files to update referenced earlier in this thread, docker and pip commands are not found, plus /usr/local/lib is empty and /usr/src does not existā¦( is this because Iām SSHād into the docker container running the HA instance and not the actual host machine ?)
Just go to the componants folder and find ring. I bumped the manifest version to .9 and it fixed my issue.
Like I said by post , in donāt have access to the components folder from Hassio which is why I was asking for a āguideā on how to do this
Hi, I have hassio on rpi and I have it fixed without accessing the hidden folders. Just follow the procedure mentioned some posts above (im on my phone, so here it is from memory) -
Have ha latest update
Disable 2fa on your ring account
Delete the pickle file from config folder
Restart ha - see that now ring works
Re-enable 2fa on your ring account
Restart again ha - see that now ring works
Cheers.
if you scroll up
its there a numer of times
dependant on your system
I appreciate the replies, but Iām asking for help because Iāve tried all the things mentioned in this thread, and as I have said a number of times, I donāt have access to any of the files and folders described.
phil@Desktop-PC:~$ ssh root@hassio
_ _ _
| | | | (_)
| |__| | __ _ ___ ___ _ ___
| __ |/ _` / __/ __| | |/ _ \
| | | | (_| \__ \__ \_| | (_) |
|_| |_|\__,_|___/___(_)_|\___/
Our Cli:
$ hassio help
~ $ cd /
~ $ ls /usr/src
ls: /usr/src: No such file or directory
~ $ ls /usr/local/lib
~ $ ls /srv
~ $ ls /home
/ $ find . -name ring
/ $ find . -name ring*
/ $ find . -name requirments_all.txt
/ $ find . -name manifest.json
./config/custom_components/hacs/manifest.json
./config/custom_components/badnest/manifest.json
~ $ pip
-bash: pip: command not found
~ $ docker
-bash: docker: command not found
Again, I canāt find any of the āstuffā referenced in this thread. Thoughts ?
Well my post about this is 9 and 10days ago
From where you are you need to go into the docker container. To get to the files.
Type
docker exec -it homeassistant /bin/bash
That will get you in
You land at the config folder
the python library are located in
/usr/local/lib/python3.7/site-packages
The homeassistant components are located in
/usr/src/homeassistant/homeassistant/components
George, if you read my last post you will see that when I SSH into my HASSIO instance (with protected mode turned OFF) and type dockerā¦ i getā¦
_ _ _
| | | | (_)
Our Cli:
$ hassio help
~ $ docker exec -it homeassistant /bin/bash
Also,
There is NOTHING in /usr/local/lib.
This is the third time Iāve exactly described my problem, but no one seems to understandā¦ Is it me ?, Is there something Iām fundamentally failing to understand here ?
Iām not an expert, so forgive if this is bad advice.
Have you tried running the āloginā command right after you ssh into hassio, and then run the docker commands?
_ _ _
| | | | (_)
Our Cli:
$ hassio help
~ $ login
core-ssh.local.hass.io login:
Login timed out after 60 seconds
are you opening the web ui or are you connecting via ssh
you should just be using the open web ui or the terminal from the side menu bar in HA
i just tried it on my system Ubuntu/Docker/Hassio and my office Hyper-V VM running Hassio
on both occasions
docker
did not come back as not found
Hi George,
Iāve tried SSH from a terminal and from the Web UI as you describe, with exactly the same results
Clearly there is some fundamental difference between out installsā¦, mine is on a Raspberry Pi installed using a prebuild HASSIO .img file
2 questions
what is your setup
can you install portainer addon
Hi George,
I could install portainerā¦, what does it do ? (looks pretty heavyweightā¦)
or do I need to follow the SSH guide I found buried here:
https://developers.home-assistant.io/docs/en/hassio_debugging.html
not much really
unless your heavily into docker
but its get you into the console of the homeassistant container
let me rephrase that
it should get you into the console
well if portainer doesnt do it for you
right now quicker to install the addon
than having to generate a authorized key etc
Updated to 0.103.5 and it works now fine
