Ring integration setup fails
I tested ring now with the newest Hassio Version
0.103.4
For me its still not running.
Thu Dec 26 2019 21:05:07 GMT+0100 (Mitteleuropäische Normalzeit)
Unable to prepare setup for platform ring.sensor: Unable to set up component.
Ring Setup
Error: 401 Client Error: Unauthorized for url: https://api.ring.com/clients_api/session
You will need to restart hass after fixing.
+1 for the fix by @tekmaven. Worked for me as well.
Hopefully we’ll get "correct’ OAUTH2 in the near future.
The ring-doorbell code now has the OAuth2 code in version 0.2.6
you can wait for HA release update or update it now !
This is the most simplest way
Hassio
Add-ons - SSH & Web Terminal
Protection Mode Off (:thinking: )
open Open Web UI
type the following
docker exec -it homeassistant /bin/bash
pip install ring-doorbell==0.2.6
exit
click the <----
Protection Mode On (:slight_smile: )
restart HAHassio
This didn’t appear to work for me. I upgraded and I now have 0.2.8 in HA. As such, I removed the header “hack” from init.py and then rebooted HA. It came up with the same denial. I then removed the .ring_cache.pickle file as well, rebooted HA, same result.
Is there anything required to initiate the OAuth2 connection?
0.2.8 ?
Where in HA
Download the zip
Extract the ring_doorbell folder only
Copy it to the samba share over the network to the config folder
From terminal docker session
Type
cp -r /config/ring_doorbell usr/local/lib/python3.7/site-packages/
If your running 3.6 its a different path
This didn’t work for me, either.
This did not work for me either
Manually updating the requirements_all.txt and the components/ring/manifest.json in the homeassistant src folder in my hassos installation worked for me, thank you. a manual pip install got overwritten when I restarted hassio.
Okay I see
Marcelo has been bumping the version since i looked at it he’s now at 0.2.9 but that hasn’t fully updated to the dist.
I can only confirm that it all works for me even on 0.2.6 and now 0.2.8.
I Can Confirm That
I never hacked the components/ring/init.py
I never used the custom_components hack
Tests I Just Performed
Ring was working For Me
i ran through the following just now as a test
I Remove The ring-doorbell
bash-5.0# pip uninstall ring-doorbell
Uninstalling ring-doorbell-0.2.6:
  Would remove:
    /usr/local/lib/python3.7/site-packages/ring_doorbell-0.2.6.dist-info/*
    /usr/local/lib/python3.7/site-packages/ring_doorbell/*
Proceed (y/n)? y
  Successfully uninstalled ring-doorbell-0.2.6
I Installed The ring-doorbell
bash-5.0# pip install ring-doorbell
Collecting ring-doorbell
  Using cached https://files.pythonhosted.org/packages/e3/b9/c9ceb6d286f95d7ee640e248556977c0fe02a821b7a7f879d950c413cdf8/ring_doorbell-0.2.8-py3-none-any.whl
Requirement already satisfied: requests==2.22.0 in /usr/local/lib/python3.7/site-packages (from ring-doorbell) (2.22.0)
Requirement already satisfied: requests-oauthlib==1.3.0 in /usr/local/lib/python3.7/site-packages (from ring-doorbell) (1.3.0)
Requirement already satisfied: pytz in /usr/local/lib/python3.7/site-packages (from ring-doorbell) (2019.3)
Requirement already satisfied: oauthlib==3.1.0 in /usr/local/lib/python3.7/site-packages (from ring-doorbell) (3.1.0)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.7/site-packages (from requests==2.22.0->ring-doorbell) (1.25.7)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.7/site-packages (from requests==2.22.0->ring-doorbell) (2.8)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.7/site-packages (from requests==2.22.0->ring-doorbell) (3.0.4)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/site-packages (from requests==2.22.0->ring-doorbell) (2019.11.28)
Installing collected packages: ring-doorbell
Successfully installed ring-doorbell-0.2.8
bash-5.0#
Now@ ring-doorbell 0.2.8
I Updated The manifest.json In The components/ring Folder
  "domain": "ring",
  "name": "Ring",
  "documentation": "https://www.home-assistant.io/integrations/ring",
  "requirements": ["ring_doorbell==0.2.8"],
  "dependencies": ["ffmpeg"],
  "codeowners": []
I removed the pickle file.
I rebooted the whole system.
Ring Is Still Working for me.
Harry, thanks for documenting that…
The key appears to be updating the manifest.json file so it doesn’t overwrite the ring_doorbell file on reboot.
Thanks!
I got it working using the following steps. Thanks to @Harry13, @pickerin, and @tom_w!
  1. Install ring-doorbell 0.2.8
  2. Update requirements_all.txt and manifest.json changing the ring component version to 0.2.8.
  3. Delete .ring_cache.pickle
  4. Reboot
I basically did the same thing, but didn’t have to update the requirements_all.txt…it’s working so far.
Where are the “requirements_all.txt” and “manifest.json” files? I’m running HASSIO and can’t find them.
Look at my post a bit further up
8h before this to get the access
Location is
cd /usr/src/homeassistant/homeassistant/componets/ring
I see that you said they are in the components/ring folder. But I don’t have a components folder, at least I can’t find it. I have a custom_components but I know that’s not it.
Sorry in the car so hard to type
But all explained above
If you’re using a Hass.io Add-on for the terminal then make sure you turn off Protection Mode.
Thanks, I did that. I was eventually able to find the json file. Just made the changes and rebooted and all is working as expecting so far. Thanks to this thread.
Steps to upgrade ring 0.2.8 on hassbian
# sudo systemctl stop [email protected]
# sudo nano /srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/ring/manifest.json
change X.2.X to 0.2.8
# sudo rm /home/homeassistant/.homeassistant/.ring_cache.pickle
# sudo -u homeassistant -H -s
# cd /srv/homeassistant
# python3 -m venv .
# source /srv/homeassistant/bin/activate
# pip3 uninstall ring-doorbell
# pip3 install ring-doorbell
# reboot
Confirmed working hassbian 0.102.3
