I’ve adapted @ImSorryButWho excellent blueprint to work with the manual alarm card, which then triggers the Aqara M1S security controls.
Does anyone know how to make the keypad work without using the manual alarm card?
If I have to use the manual alarm card, how can i get the keypad to turn the away button red and to get the keypad to display the arming count down?
blueprint:
name: Ring Keypad Automations
description: Automations to use the Ring Keypad with an Alarm Panel integration. See https://github.com/ImSorryButWho/HomeAssistantNotes/blob/c9727e2d2d4e863ac58f61b23939bab9532e4fef/RingKeypadV2.md for more information.
domain: automation
input:
keypad:
description: The device entry for the Ring keypad
selector:
device:
manufacturer: Ring
integration: zwave_js
alarm:
name: Alarm Control Panel entity
description: The Alarm Control Panel to synchronize the keypad with
selector:
entity:
domain: alarm_control_panel
selected_action_police:
name: Selected Action Police
description: Select the action for Police Button
default: []
selector:
selected_action_fire:
name: Selected Action Fire
description: Select the action for Fire Button
default: []
selector:
selected_action_medical:
name: Selected Action Medical
description: Select the action for Medical Button
default: []
selector:
variables:
alarm: !input alarm
mode: parallel
max: 10
- platform: event
event_type: "zwave_js_notification"
event_data:
command_class: 111
device_id: !input keypad
event_type: 2
- platform: event
event_data:
command_class: 111
event_type: 3
- platform: event
event_data:
command_class: 111
event_type: 5
- platform: event
event_data:
command_class: 111
event_type: 6
- platform: event
event_type: zwave_js_notification
event_data:
command_class: 111
device_id: !input 'keypad'
event_type: 16
- platform: event
event_data:
command_class: 111
event_type: 17
- platform: event
event_data:
command_class: 111
event_type: 19
- platform: event
event_type: "alarmo_failed_to_arm"
event_data:
reason: "invalid_code"
- platform: event
event_data:
reason: "open_sensors"
- platform: state
entity_id: !input alarm
to: disarmed
- platform: state
to: arming
- platform: state
to: armed_away
- platform: state
to: armed_home
- platform: state
to: pending
- platform: state
to: triggered
choose:
- conditions:
- condition: trigger
id:
- code_entered
- keypad_disarm
sequence:
- service: alarm_control_panel.alarm_disarm
code: "{{ trigger.event.data.event_data }}"
- conditions:
- condition: and
conditions:
- condition: state
state: "disarmed"
sequence:
- service: alarm_control_panel.alarm_arm_away
- conditions:
- condition: and
conditions:
- condition: state
state: disarmed
sequence:
- service: alarm_control_panel.alarm_arm_home
- conditions:
sequence:
- service: zwave_js.set_value
command_class: "135"
endpoint: "0"
property: "9"
property_key: "1"
value: 1
- conditions:
sequence:
endpoint: "0"
property: "16"
property_key: "1"
value: 1
- conditions:
sequence:
endpoint: "0"
property: "2"
property_key: "1"
value: 1
- conditions:
sequence:
endpoint: "0"
property: "11"
property_key: "1"
value: 1
- conditions:
sequence:
endpoint: "0"
property: "10"
property_key: "1"
value: 1
- conditions:
sequence:
endpoint: "0"
property: "18"
property_key: "7"
value: "{{ state_attr(alarm, 'delay')}}"
- conditions:
sequence:
endpoint: "0"
property: "17"
property_key: "7"
- conditions:
sequence:
endpoint: "0"
property: "13"
property_key: "1"
value: 1
- conditions:
sequence: !input selected_action_fire
- conditions:
sequence: !input selected_action_police
- conditions:
sequence: !input selected_action_medical
