I had to factory reset and re-add all my sensors to my ring bridge after issues with the bridge itself. Before I did this, all sensors were working in HA using the Ring-Mqtt integration.
Since re-adding I have restarted HA a few times and also regenerated the token. However, some of the sensors are not showing in entities. I cannot see a pattern - some are contact ans some motion.
It is difficult to identify the sensors that are OK in Ha in in the mqtt queue so wondering if there is any obvious situation where sensors do not create mqtt rows?
Update: reloaded ringmqtt separately from a system restart and all the sensors appeared
