2022-05-20T13:57:49.248Z ring-mqtt [Front Door] Received set live stream state ON-DEMAND
2022-05-20T13:57:59.233Z ring-rtsp INF [path e04f43a47a81_live] runOnDemand command stopped
2022-05-20T13:57:59.233Z ring-rtsp INF [RTSP] [conn 172.30.32.1:54116] closed (source of path 'e04f43a47a81_live' has timed out)
2022-05-20T13:57:59.233Z ring-rtsp INF [RTSP] [conn 172.30.32.1:54114] closed (source of path 'e04f43a47a81_live' has timed out)
2022-05-20T13:57:59.233Z ring-rtsp [Front Door] Deactivating live stream due to signal from RTSP server (no more active clients or publisher ended stream)
2022-05-20T13:57:59.240Z ring-mqtt [Front Door] Received set live stream state OFF
2022-05-20T13:57:59.240Z ring-mqtt [Front Door] Stopping live stream session on workerId
OK, so I’ve been working on this for awhile and it seems that with the latest update it is more strict/picky about a username and password. I set them up in the Ring-MQTT config then changed my RTSP link to include them. Seems to have fixed the issue. I hope this helps someone.
You set a username and password in the configuration section of the RingMQTT add-on then make sure the same are configured in the generic camera settings.
