Ring MQTT - Unavailable
Hi!
I don’t know what happend but all my RIng devices became unavailable…
I have already re-configure everything but nothing changed…
Any sugestion?
I have been having issues with Ring and Govee to MQTT with this last update and have had to restart the add-on in order to get them back after a reboot.
I also have been wihth a couple issues after the update but today they went all unavailable and I’m not beeing able put the them available again…
The last updates of home assitant this year are killing my smart home! too many bugs…
There was a post on the Ring MQTT thread that a token authorization issues at Ring required a reboot of the integration to get it working again. Might be worth a read there first to find out the background.
Hello, I did get a new authorization token and restarted HA and still the same issue, anyone get this resolved? Thank you.
Still no solution for me…
I was having the same issue with the Ring-MQTT with Video Streaming add-on. Re-authorization of the add-on didn’t work by itself, but then restarting the add-on after that appears to have fixed it.
Thank you, this was racking my brain. This worked for me also. It took about 30 seconds after restarting the add-on to start getting data.
Restarting the addon worked for me.
I didn’t do it initially as I had tried restarting all of home assistant which hadn’t worked. I don’t quite understand the difference as I assumed restarting HA OS would also restart the addon but nevertheless its all working now. Thank you!
I have to do that a lot after I reboot. Reboot HA then reboot RingMQTT and things all are back to working.
