Ring, new integration fails auth token
Hi all,
New user here, decided to add my Ring doorbell this afternoon, but getting the following error.:
oauthlib.oauth2.rfc6749.errors.AccessDeniedError: (access_denied) token is invalid or does not exists.
I don’t have 2FA switched on and as far as I can tell I’ve added the integration correctly in my config file:
ring:
  username: !secret email
  password: !secret ring_pw
Is it a system thing or have I done something wrong?
Many thanks, P
Are you running the latest version of Hassio?
There has been ongoing changes with the Ring integration and you will likely get more help on this thread.
https://community.home-assistant.io/t/ring-integration-setup-fails/
I’m using Home Assistant 0.103.5
Updated earlier today.
Thanks, I’ll check out that thread.
Ta
