For some reason roughly 8 hours ago all my ring devices through ring to mqtt have gone offline.
I reauthorized it, restarted, resintalled, but nothing changed and all my devices are offline.
Several key points stand out from the logs:
Repeated HTTP 500 Errors: The add-on consistently receives HTTP 500 errors over multiple attempts to communicate with the Ring service, indicating a persistent issue.
Unhandled Promise Rejections: These warnings suggest that the code is not properly handling errors that occur during asynchronous operations. While this might not be the cause of the communication errors, it indicates potential areas for improvement in the add-on’s error handling.
