I was trying to use GoogleHome/HomeKit to adjust the temperature of my Rinnai Tankless heater and ran into so many problems. So I started over and used a generic_thermostat integration named Faucet
. Note that a couple of fields are required but not used so they were defined with xxx
climate:
- platform: generic_thermostat
initial_hvac_mode: heat
unique_id: thermostat_faucet
heater: switch.xxx
target_sensor: sensor.xxx
min_temp: 120
max_temp: 140
precision: 1.0
after exposing Faucet
to GH/HomeKit so then a simple command like:
Hey Google, set Faucet to 125 degrees
This will change the Temperature attribute on the “thermostat”.
This automation will adjust the tankless heater when any state of Faucet
changes.
alias: FaucetStateChanged
description: When genric therm faucet changes, update waterheater to match
- platform: state
entity_id:
- climate.faucet
condition:
- condition: template
value_template: "{{ (states.climate.faucet.state != \"off\")}}"
enabled: true
- service: water_heater.set_temperature
temperature: "{{ state_attr('climate.faucet', 'temperature') }}"
entity_id: water_heater.your_rinnai_water_heater
enabled: true
mode: single
Of course you can use Faucet
in Lovelace and other automations/scripts etc.
Now I like a lower temperature for things like washing my hands, so I usually keep it at 120°. But if I’m taking a shower I might like it higher, so I can adjust it with my voice. But now I was thinking (insert joke here), why not adjust the temperature automatically? So what would a trigger look like? What attributes of the Rinnai might determine someone is hot water more than washing hands?
