Since a while we get timeouts on the Risco Cloud integration. The log is full with the following errors:
Strange thing is that when we wait, try again it works…
Logger: homeassistant.components.risco
Source: helpers/update_coordinator.py:204
Integration: Risco ([documentation](https://www.home-assistant.io/integrations/risco), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+risco%22))
First occurred: 10 mei 2023 om 20:41:44 (1780 occurrences)
Last logged: 12:09:32
* Error fetching risco data: {'result': 72, 'validationErrors': None, 'errorText': None, 'errorTextCodeID': None, 'status': 200, 'response': None}
* Error requesting risco_events data: Cannot connect to host www.riscocloud.com:443 ssl:default [Try again]
* Error requesting risco data: Cannot connect to host www.riscocloud.com:443 ssl:default [Try again]
* Error requesting risco_events data: Cannot connect to host www.riscocloud.com:443 ssl:default [Connect call failed ('51.124.48.37', 443)]
* Error fetching risco_events data: Invalid username or password
Hope that you could help
Running 2023.2, Using the official Risco integration.
