I found a github project which allows from integration via homebridge: https://github.com/szlaskidaniel/homebridge-risco-alarm
Could this perhaps be ported to Home Assistant as a component?
I’m also interested in that
Same here, marked as watching
Also interested. Voted and watching.
Interested too!
i asked risco for API, we will see what they respond
well, first link below is a .PY script, at the moment it doensnt work anymore, because riscocloud changed the login a few months ago, so this script needs to be changed a litte bit, then we can maybe use it as a custom component… so any1 here with python abilities?
this one below, is a nodejs script, its currently working in HA, i am using it in a docker , then with mqtt
one big disadvantage is that the state armed/disarmed isn only changing afer 3-4 minutes
maybe someone can improve it and maybe also convert it to a python version?
Do you know if they have some API documentation since their redesign? I see, by looking quickly at the code, that JSON code can be extracted from the risco endpoints, correct?
No, no API, well there is, but they don’t share it…
Are you programmer? Can you update/make a python from it? The nodejs is working also, but we need then extra addon
I would be willing to pay for someone to send a guide to hassio
for the python version you mean?
For anything working on hassio
Same here
But the nodejs version is already working, the python needs to be updated
I do not run it on hassio, not with nodejs or anything.
someone who can help me to run it on hassio, i need a guide for sillys
The only working is the mqtt one, a few posts above… All guide are on GitHub
i tried several times and i cant do it run
where are you stuck? did you run the docker version ? more info please
I’m on hass.io, I tried it several times with portainer but I can’t do it runs
What error do you have? What is not running? Make some screens please,
