hmm, maybe your device isnt supported? why are you using proxy method anwyay? i have a verry old lightsys, i can only make 1 connection, thats wht i use proxy, because i also want to use cloud too
That is exactly the reason why Iām looking at proxy - To have best of both worlds. My wife still uses the Risco app occasionally. My panel is about 5yrs old.
Iām running on a RPi4 if that could be an issueā¦
Trying to install this at a friends house
I made a cp user in risco cloud
However i only need to fill in a name and a pincode
The integration however asks for username, password and pincode
What am i doing wrong?
Edit: i read its possible now to do everything local
What are the benefits?
GOOD/BAD for both methods?
It looks kinda hard to setup too.
For my friend i would go cloud first, but want to try local too
i enjoy the local one too
one big advantage for me, its NOT based on polling, so the PIR sensors dont have any delay, and can be used for automations to turn on a light for example
yeah thats one advantage why m considering it
the motion sensors react too slow with cloud
Can you help me set it up locally pls?
What are the steps?
Iām running HA OS
Whats the requirement: * Node.js (currently tested with >=ver. 10.x)
How do i get this if i havent got it? (not sure)
Where do i put the config file? config.json
Do i need to do something in the risco cloud ui?
I assume as soon as i start the addon with the json, the app ownt work anymore?
Can i also publish everything from risco under a mqtt topic risco?
If i have an old panel RW132IP direct mode wont work if risco cloud is enabled
So i have 2 options then:
or use the proxy (advanteges? use app still posisble?)
or use direct but then i must therefore deactivate RiscoCloud and then restart my control panel (or the IP module by deactivating it and then reactivating it in the configuration from the keyboard). This action will prevent the control panel from connecting to RiscoCloud and i will no longer be able to use it remotely from the iRisco application.***
How can i know, which panel im using? to know if i can use direct or notā¦
