ah crap, have to redo everything then?
Why? Itâs even easier now, also no mqtt needed
The names of entities , just rename them
Or stick with addon , your choiceâŚ
I still going to use addon, because I need a proxy
Really?
Hows that? No mqtt?
Will it be as fast as the addon using mqtt?
Still able to use the cloud?
Also need to adjust the alarm panel to get rid of the cloud setting?
Yes , you can choose cloud or local
Local still needs a new TCP board, thatâs the same as with addon , so if you have old board , you need a proxy or disable cloudâŚ
ok so in fact it will be the same as addon?
Why keep using addon then?
Because I need the proxy, the official integeration doesnât have it , and I donât want to disable cloud
ah ok i see
what are the benefits of using the official one, instead of addon when i disable cloud and i normally use mqtt
Just easier to use , thatâs all, and no need for 2 extra add-ons (Risco & mqtt)
The functions are identical , itâs the same library
Mmm i still need mqtt for my other stuff , so would be 1 less addon
But will it be as fast as mqtt?
Yes , itâs same code
- Youâll be able to choose whether you want to require code on arm/disarm
- Support for group arming, and mapping between Risco modes and HA modes (like in the existing cloud integration)
- No need for an external service
Hello guys. Now that risco is moving to subscription, does anyone know how to change the XML server they use to a local one in order to interface with hassio?
Local connection is now part of the new Beta 2022.9 , just wait a few more days
But remember, if you have an old TCP board that only allows 1 socket connection, you need to turn off the cloud âŚor make a proxy
Are there plans to include the proxy in the future?
No , not on the list, we have Todo this on our own
Thx! Will be a valuable feature should it ever be included. Currently using the add-on with proxy built-in and it works very well.
Yess, will use that one too for now, untill a proxy is being created by someone
Which proxy?
Sharing to all my current setup:
- Ubiquity Edge Router with Open VPN setup
- SIM card from 1nce.com - instructions for Open VPN are very simple and provided online
Risco alarm panel is connected via private network and visible from Hassio server.
Panel using Hassio address as server in port 33000
Now, how to make use of it? Port 1000 is closed on alarm pannelâŚ
