well, if you start that container, check that log file on container, normally it should start with:
connecting to risco …
connecting to mqtt
polling…
then it should be ok
but remember, if you arm/disarm, from a hardware panel, there is a delay of like 5 minutes, before the state gets changed in HA
if you change arm/disarm, from riscocloud/app , it should be instant
The log looks fine, and if I arm/disarm from the alarm keypad it syncs correctly with HA, but this time I disarmed from HA. It disarmed the alarm but it’s not receiving the disarmed state from risco cloud. In fact when I said I manually changed the state to disarmed I now notice that it’s reverted back to armed_away. I don’t know why, I’m sitting at home and the alarm is disarmed.
[edit] okay I’ve just had another facepalm moment. I have 2 partitions setup on my system. What I have only just realised is that by disarming from HA it only disarmed the primary partition. I just opened the alarm app and realised the other partition was still armed. That is obviously why when HA was polling the cloud it was still seeing it as armed_away (because it doesn’t handle multiple partitions) [/edit]
how you did it,did u copy the addon repository to addon folder and then install it?not working for me?
i think ill continue with luca project,its is working for me really fine
maybe im not lucky with this,thanks for all again
show me this in system log:
19-07-10 21:28:42 ERROR (SyncWorker_5) [hassio.docker.interface] Can’t install mgrayson/armhf-risco-hass-bridge:0.1 -> 404 Client Error: Not Found (“pull access denied for mgrayson/armhf-risco-hass-bridge, repository does not exist or may require ‘docker login’”).
good news guys, just got information that risco wil launch soon a public API for developers, they will inform me next week about ETA
seems they also finished integration with amazon alexa already, probably launching verry soon
hi,i need help again,What would be the path of the container of a hassio installation in docker?
/mnt/data/supervisor/homeassistant/risco-mqtt-bridge/config.js doesnt work
thanks again
Solved, for those interested in the route is:
/usr/share/hassio/homeassistant/
are you running luca version? then you need a docker update, luca updated his docker
risco changed the cloud last week, upgraded to 5.2 , so the docker was also updated
see here more info:
