I had RM mini 3 working just fine with HASSIO 0.101 and RM Mini 3 v55
I upgraded to HASSIO 0.102.3 and started getting this error:
[homeassistant.components.broadlink.switch] Failed to connect to device
IHC works just fine and the IP has not changed…
I proceeded to update to RM Mini v57 but still same problem. It must be something with HA.
I haven’t made any changes to my broadlink component in several months so I doubt that 102.3 breaks the broadlink component. One thing I would check is to see if the RM will go into learning mode from HA. If not, I suspect that your broadlink may have picked up a different IP. If you RM3 was working in .101, then nothing needs to be changed to your config file. It has to be your RM
I have a BroadLink RM mini 3 and I have lots of problems while using HA.
I’m 100% sure it’s not the IP address, the device gets it from the DHCP on my router and it’s set fixed for that MAC.
But… I did notice the device timing out on ICMP (even with the device is right next to the router)
and this happens ALOT.
I also noticed that sometimes the device does not respond when you send commands from HA (with the well known error message in the logs: Failed to connect… but the device is pingable) but then after restarting the HA instance it starts responding (also tried to restart the BroadLink device but that doesn’t help).
So I think the Wifi module of the device is poor quality or maybe even broken on mine but there is still an issue within HA also.
Another strange issue I have now is using automation. It used to work and the script I use does still work when I call it manually but it refuses to work in automations. But I need to look into this issue a bit more.
I have now also bought a RM pro, will test things with that device next weekend and see if there is any difference between the two devices.
I also had an issue where RM Mini 3 stopped working. I had a RM Pro downstairs and RM Mini 3 upstairs. The RM Mini 3 completely stopped working for no apparent reason. No errors.
The RM Pro continued to work fine. Looking at type for each device I had rm_pro_phicomm for the RM Pro and rm_mini for the RM Mini 3. I changed the device type on the RM Mini 3 to also be rm_pro_phicomm and it works perfectly again.
My rm mini stop work too.
Not only with HA, I can’t even reset it (blue light doesn’t blink after holding reset button. Does anyone know how to fix it?
Yes it changed and it messed up for me.
I added the integration, it created an entity.
Now when I call a script, it calls it twice!
Same script as I had before.
I even tested the call in the dev tools section to see what’s happening, I observed the following:
Service: remote.send_command
Entity: remote.broadlink_rm_pro_3_remote
device: 32756745 -> this was added by the interface
command: >-
b64:********** huge string of data I send (which has not changed and has always worked) *********
When I click ‘call service’, it executes 2 times.
So when I have a toggle (which it is in my case) it turns my device on and back off after a second.
