I have an RM PRO 3 which I am using to send RF signals to light switches.
When i trigger it to send an RF single, if it has been in-active for 20 mins or so, the 1st command it sends either fails or is sent twice, (which turns the light back off)
Every other command sent after is completely fine and works perfectly.
This have tried sending a “dummy signal” then a delay of 1 second then the real signal to wake it up. This has about a 60% success rate, but sometimes the 1 second delay isn’t enough and fires the real signal halfway through the “dummy wake up signal” is there anyway to fix this?
