Road Conditions API
I’m trying to setup a api or feed from a travel information site. I’m just not sure how to do it. Should I setup a rest sensor for the api in HA or NodeRed? Here is the link to the API site and how do I use the JSON or if I need to?
https://511on.ca/help/endpoint/roadconditions
I would use the HA rest sensor, with the json output.
There is absolutely no use to use node-red, if you wanted to do that you’d be best to ask in a node-red forum.
Hi, were you able to do this, can you help with config please?
What are you after from the api?
Just want to know of road/lane closures on specific highways such as 403 etc
