Thanks for your work - it helped a lot.
But I am still struggling with my configuration.
A config check gave me - Integration not found: mower_name_command -
Not sure what is wrong cause I did a copy /paste.
Thanks,
Gernot
Thanks,
Gernot
I think I missed a line when I pasted this code, this is a chunk defining an input_select:
input_select:
mower_name_command:
name: mower_name Set State
options:
- status_quo
- start
- stop
- auto
- home
- man
- eod
initial: status_quo
icon: mdi:robot
Can someone share latest config file of this integration because mine doesn’t work anymore
…maybe because i made a robonect update
Is it possible to set a Timer with Automations?
For Example.
set to Auto and 3h later set to Home
Yes. Easiest would be to set it to auto on one timeframe and than 3h later to end of day.
To restart thius discussion: implemented as described above.
What i am missing is two things:
Anyone already did this?
/ Ralf
Use the Rest API. An example can be found here: https://robonect.net/viewtopic.php?f=29&t=19
The best would be if the rest Api and Mqtt were one to one in an functional aspect but that is not the case right now. Push (mqtt) works so much better then pull (rest sensor)…
@fn87: Thanks for the note: i see a mqtt topic is available for “TOPIC/mower/stopped”. Maybe this is the one i thought of, will try.
But i am still missing information how to retrieve the status of the blade status?
/ Ralf
EDIT: just found it: run http://192.168.178.59/json?cmd=status, then “grep” for the “blades”.
If i have some time free, will try this and post my solution here. Maybe takes some time…
Something like this should work:
- platform: rest
resource: http://192.168.XX.XX/json?cmd=status
value_template: "{{ value_json.blades.quality }}"
username: X
password: X
json_attributes_path: '$.blades'
json_attributes:
- hours
- days
I am at a loss here about how should i set this up.
I created an automations.yaml -file, copy-pasted the scripts there. Did the same to other files.
I have some experience with simple esp8266 temperature sensors around the house using mqtt to get the values but i cannot grasp the concept how this integration has been set up.
What the end result looks like? What card is added from the overview menu?
Sorry to be a total doofus about this but i did not grasp the concept from this thread yet
If you have set up your mower correctly the data will added to the senors through MQTT. Have you added the MQTT settings in Robonect?
I can’t seem to get the communication from HA to robonect to work. I get the data from the mower from mqqt, but nothing happens on the robot when I change in the input select list. Any clews?
anybody translated all this configuration to the new model for MQTT already? Is it simply all same but only the sensors "sensor: - platform: mqtt state_topic: " ist to be changed to “mqtt: sensor: - state_topic:” and it should work the same as before?
I would not do this, if you want to change anyway. Just use the publish service and the discovery way) to avoid all the yaml-loads, etc. Put it in a script, run it once (!) and you have all the entities and on top a device (which is not possible with yaml config). Here my config.
alias: MQTT Discovery Huqvarna Automower 330x
sequence:
- service: mqtt.publish
topic: homeassistant/sensor/mahroboter_gps_breitengrad/config
retain: true
payload: |
"state_topic": "automower/gps/latitude",
"name": "Mähroboter GPS Breitengrad",
"unique_id": "unique_id_mahroboter_gps_breitengrad",
"object_id": "mahroboter_gps_breitengrad",
"icon": "mdi:crosshairs-gps",
"device": {
"identifiers": ["330x"],
"name": "Husqvarna Automower 330x",
"model": "330x",
"manufacturer": "Husqvarna",
"sw_version": "4.05.00"
topic: homeassistant/sensor/mahroboter_gps_langengrad/config
retain: true
payload: |
"state_topic": "automower/gps/longitude",
"name": "Mähroboter GPS Längengrad",
"unique_id": "unique_id_mahroboter_gps_langengrad",
"object_id": "mahroboter_gps_langengrad",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_gps_anzahl_satelliten/config
retain: true
payload: |
"state_topic": "automower/gps/satellites",
"name": "Mähroboter GPS Anzahl Satelliten",
"unique_id": "unique_id_mahroboter_gps_anzahl_satelliten",
"object_id": "mahroboter_gps_anzahl_satelliten",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_luftfeuchte/config
retain: true
payload: |
"state_topic": "automower/health/climate/humidity",
"name": "Mähroboter Luftfeuchte",
"unique_id": "unique_id_mahroboter_luftfeuchte",
"object_id": "mahroboter_luftfeuchte",
"device_class": "humidity",
"state_class": "measurement",
"unit_of_measurement": "%",
"icon": "mdi:water-percent",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_temperatur/config
retain: true
payload: |
"state_topic": "automower/health/climate/temperature",
"name": "Mähroboter Temperatur",
"unique_id": "unique_id_mahroboter_temperatur",
"object_id": "mahroboter_temperatur",
"device_class": "temperature",
"unit_of_measurement": "°C",
"icon": "mdi:thermometer",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_batteriespannung/config
retain: true
payload: |
"state_topic": "automower/health/voltage/batt",
"name": "Mähroboter Batteriespannung",
"unique_id": "unique_id_mahroboter_batteriespannung",
"object_id": "mahroboter_batteriespannung",
"device_class": "voltage",
"unit_of_measurement": "V",
"icon": "mdi:sine-wave",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_betriebsspannung_maher/config
retain: true
payload: |
"state_topic": "automower/health/voltage/ext33",
"name": "Mähroboter Betriebsspannung Mäher",
"unique_id": "unique_id_mahroboter_betriebsspannung_maher",
"object_id": "mahroboter_betriebsspannung_maher",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_betriebsspannung_robonect/config
retain: true
payload: |
"state_topic": "automower/health/voltage/int33",
"name": "Mähroboter Betriebsspannung Robonect",
"unique_id": "unique_id_mahroboter_betriebsspannung_robonect",
"object_id": "mahroboter_betriebsspannung_robonect",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_batterie/config
retain: true
payload: |
"state_topic": "automower/mower/battery/charge",
"name": "Mähroboter Batterie",
"unique_id": "unique_id_mahroboter_batterie",
"object_id": "mahroboter_batterie",
"device_class": "battery",
"icon": "mdi:battery",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_messertage/config
retain: true
payload: |
"state_topic": "automower/mower/blades/days",
"name": "Mähroboter Messertage",
"unique_id": "unique_id_mahroboter_messertage",
"object_id": "mahroboter_messertage",
"unit_of_measurement": "Tage",
"icon": "mdi:terraform",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_messerstunden/config
retain: true
payload: |
"state_topic": "automower/mower/blades/hours",
"name": "Mähroboter Messerstunden",
"unique_id": "unique_id_mahroboter_messerstunden",
"object_id": "mahroboter_messerstunden",
"unit_of_measurement": "Stunden",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_messerqualitat/config
retain: true
payload: |
"state_topic": "automower/mower/blades/quality",
"name": "Mähroboter Messerqualität",
"unique_id": "unique_id_mahroboter_messerqualitat",
"object_id": "mahroboter_messerqualitat",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_fehlercode/config
retain: true
payload: |
"state_topic": "automower/mower/error/code",
"name": "Mähroboter Fehlercode",
"unique_id": "unique_id_mahroboter_fehlercode",
"object_id": "mahroboter_fehlercode",
"icon": "mdi:alert-circle",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_fehlernachricht/config
retain: true
payload: |
"state_topic": "automower/mower/error/message",
"name": "Mähroboter Fehlernachricht",
"unique_id": "unique_id_mahroboter_fehlernachricht",
"object_id": "mahroboter_fehlernachricht",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_betriebsstunden/config
retain: true
payload: |
"state_topic": "automower/mower/statistic/hours",
"name": "Mähroboter Betriebsstunden",
"unique_id": "unique_id_mahroboter_betriebsstunden",
"object_id": "mahroboter_betriebsstunden",
"icon": "mdi:timer-sand",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_status_raw/config
retain: true
payload: |
"state_topic": "automower/mower/status",
"name": "Mähroboter Status Raw",
"unique_id": "unique_id_mahroboter_status_raw",
"object_id": "mahroboter_status_raw",
"icon": "mdi:list-status",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_im_aktuellen_status/config
retain: true
payload: |
"state_topic": "automower/mower/status/duration",
"name": "Mähroboter Zeit im aktuellen Status",
"unique_id": "unique_id_mahroboter_im_aktuellen_status",
"object_id": "mahroboter_im_aktuellen_status",
"unit_of_measurement": "Minuten",
"icon": "mdi:timer",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_status_plain/config
retain: true
payload: |
"state_topic": "automower/mower/status/plain",
"name": "Mähroboter Status Plain",
"unique_id": "unique_id_mahroboter_status_plain",
"object_id": "mahroboter_status_plain",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_substatus_raw/config
retain: true
payload: |
"state_topic": "automower/mower/substatus",
"name": "Mähroboter Substatus Raw",
"unique_id": "unique_id_mahroboter_substatus_raw",
"object_id": "mahroboter_substatus_raw",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_substatus_plain/config
retain: true
payload: |
"state_topic": "automower/mower/substatus/plain",
"name": "Mähroboter Substatus Plain",
"unique_id": "unique_id_mahroboter_substatus_plain",
"object_id": "mahroboter_substatus_plain",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_nachster_start_datum/config
retain: true
payload: |
"state_topic": "automower/mower/timer/next/date",
"name": "Mähroboter Nächster Start Datum",
"unique_id": "unique_id_mahroboter_nachster_start_datum",
"object_id": "mahroboter_nachster_start_datum",
"icon": "mdi:calendar",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_nachster_start_uhrzeit/config
retain: true
payload: |
"state_topic": "automower/mower/timer/next/time",
"name": "Mähroboter Nächster Start Uhrzeit",
"unique_id": "unique_id_mahroboter_nachster_start_uhrzeit",
"object_id": "mahroboter_nachster_start_uhrzeit",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_nachster_start_timestamp/config
retain: true
payload: |
"state_topic": "automower/mower/timer/next/unix",
"name": "Mähroboter Nächster Start Timestamp",
"unique_id": "unique_id_mahroboter_nachster_start_timestamp",
"object_id": "mahroboter_nachster_start_timestamp",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_strecke_bis_startpunkt/config
retain: true
payload: |
"state_topic": "automower/mower/distance",
"name": "Mähroboter Strecke bis Startpunkt",
"unique_id": "unique_id_mahroboter_strecke_bis_startpunkt",
"object_id": "mahroboter_strecke_bis_startpunkt",
"icon": "mdi:map-marker-distance",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_modus_raw/config
retain: true
payload: |
"state_topic": "automower/mower/mode",
"name": "Mähroboter Modus Raw",
"unique_id": "unique_id_mahroboter_modus_raw",
"object_id": "mahroboter_modus_raw",
"icon": "mdi:state-machine",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_gestoppt/config
retain: true
payload: |
"state_topic": "automower/mower/stopped",
"name": "Mähroboter gestoppt",
"unique_id": "unique_id_mahroboter_gestoppt",
"object_id": "mahroboter_gestoppt",
"icon": "mdi:octagon",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_passage_geoffnet/config
retain: true
payload: |
"state_topic": "automower/passage/open",
"name": "Mähroboter Passage geöffnet",
"unique_id": "unique_id_mahroboter_passage_geoffnet",
"object_id": "mahroboter_passage_geoffnet",
"icon": "mdi:fence",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_wetterstop_aktiv/config
retain: true
payload: |
"state_topic": "automower/weather/data/break",
"name": "Mähroboter Wetterstop aktiv",
"unique_id": "unique_id_mahroboter_wetterstop_aktiv",
"object_id": "mahroboter_wetterstop_aktiv",
"icon": "mdi:stop",
"device": {
"model": "330x",
topic: homeassistant/sensor/mahroboter_wifi_signal/config
retain: true
payload: |
"state_topic": "automower/wlan/rssi",
"name": "Mähroboter Wifi-Signal",
"unique_id": "unique_id_mahroboter_wifi_signal",
"object_id": "mahroboter_wifi_signal",
"device_class": "signal_strength",
"unit_of_measurement": "dBm",
"icon": "mdi:wifi",
"device": {
"model": "330x",
mode: single
I meanwhile simply tried after my post and what should I tell: It works. It was not so much to re-work but still I am interested in your method as this not being all under the hood of one device annoys me a long time already. So would you mind to detail a bit how this works, the “Put it in a script, run it once (!)” in detail? I assume what you posted below as your config is the result and not the script, am I right? And how does this adapt to other models of mowers and robonects (I see GPS, mine does not have)?
No, this is already the script, not the result. So you can copy and adopt. Just remove the topics, which you don’t use or add, if I missed some. Or rename. And then only execute it. Done.
But how do you control then the mower? I cannot find any of the “automower/control” topics in your script. So the device has only sensors, but no action is possible on it. You created scripts to publish MQTT messages on each control action?
What kind of Robonect do you have? many of the topics in your script don´t even exist in mine, just checked by MQTT Explorer, e.g. I neither have any GPS nor Blades nor a “automower/mower/error” branch… Or is this dependent not on the robonect but the mower?
Didn’t get this. control via
topic: automower/control
payload: start
etc. as before. Didn’t define anything for that before in yaml. And therefor, of course, this is only the replacement for the mqtt yaml sensor entities.
Again. This is a script to add the entities (instead of defining them in config-yaml) with the pros of faster startup time, a device etc., not a automower steering script.
I have the Robonect® Hx. But I doubt, that it is related to the automower modell, but to the Robonect fw, which mqtt topics you have. Here 1.3
Missing MQTT topic branches: you´re right, updating FW to 1.3b brought some of those to mine, too.
Yes, yes. Understood: this script creates the device adding all those sensors. What I am after is to add also the control to the device like having a mode selector or start or stop buttons directly linked to the device - and not only as scripts unlinked to the device which “owns” the sensors only. Maybe this is also possible somehow?
