Is anybody using the core integration for roborock and zone cleaning? How can i get the zone coordinates?
FloleVac
Wanna bumb this topic. I want to switch from the Xiaomi Miio Integration to the Roborock integration but there is no way to call zone cleaning.
You can do it using the following code:
tap_action:
action: call-service
service: vacuum.send_command
entity_id: vacuum.roborock_s8_pro_ultra
command: app_zoned_clean
params:
- - 31122
- 25312
- 34766
- 27080
- 1
Does this work for you with the Roborock core integration?
It worked with my old roborock and Miio integration, but when I try with the roborock integration, it just cleans the whole room and not the zone. I checked with go to target that the coordinates are correct.
Yes it does work with the core integration.
Thans for confirming. I just checked and my issue was my lack of double “- -” (or double brackets in Node-RED). These are not needed for app_segment_clean or app_goto_target, but needed for the app_zoned_clean. Thanks!
How do you get the code for the “Zones”?
I am using this card.
https://github.com/PiotrMachowski/lovelace-xiaomi-vacuum-map-card
Maybe you need to install the hacs roborock integration as well.
