I need to update my Roborock custom integration; otherwise, an error will occur after the Core update 2025.3.0.
I am aware that its recommended to switch back to the core integration. However, even for uninstalling the custom integration, I would need to find it in HACS.
However, when I tried to do that, I noticed that the integration no longer appears in HACS. It’s just not there:
It is recommended you switch to the core version of this integration. Due to the time that the maintainers have, most time goes into supporting the core version of this integration as there are approximately 5 times as many users using that integration. There are multiple known issues with the custom component version of Roborock that are not planned to be fixed. If a user is so inclined - they can look at the fixes on the core component and carry them over here and we will approve PR. But otherwise, expect updates and fixes to this repository to be very limited at least for the time being.
Sorry, I forgot to add, that I am aware of this, but have scheduled the change to the core version for later for several reasons. One of them is, that I cant uninstall the custom integration, when I dont see it in HACS!
Interesting enough the developers where quick to react to the issue with core 2025.3.0 and released an update fixing the issue. However, I cant update, since I dont see it in HACS.
If you happen to have the same Problem. Here is what I found as Solution from Another Forum. Go to the github Page of the Custom Integration and reinstall the Integration again by using the ‘Add’ Button on the github page itself. This seems to refresh all the list and the Roborock Custom Integration reappears
