I Voted for this integration!
debug:
(I anonymized some data like email, token, room-names)
2023-12-09 14:12:38.529 DEBUG (MainThread) [homeassistant.components.roborock] Integration async setup entry: {'entry_id': '6734964370b0362e9c903749a0963873', 'version': 1, 'domain': 'roborock', 'title': '[email protected]', 'data': {'username': '[email protected]', 'user_data': {'uid': 1234567, 'tokentype': '', 'token': '0000000000000000000000000000000-ttttttttttttttttttttttt==', 'rruid': 'rr66666666666666', 'region': 'eu', 'countrycode': '49', 'country': 'DE', 'nickname': 'nickname_removed', 'rriot': {'u': '8KR8bflDddB7QVA2FIx5P', 's': 'eGZCOe', 'h': 'YecIoddueN', 'k': 'rMFval9o', 'r': {'r': 'EU', 'a': 'https://api-eu.roborock.com', 'm': 'ssl://mqtt-eu-4.roborock.com:8883', 'l': 'https://wood-eu.roborock.com'}}, 'tuyaDeviceState': 0, 'avatarurl': 'https://files.roborock.com/iottest/default_avatar.png'}, 'base_url': 'https://euiot.roborock.com'}, 'options': {}, 'pref_disable_new_entities': False, 'pref_disable_polling': False, 'source': 'user', 'unique_id': '[email protected]', 'disabled_by': None}
2023-12-09 14:12:38.529 DEBUG (MainThread) [homeassistant.components.roborock] Getting home data
2023-12-09 14:12:38.706 DEBUG (MainThread) [homeassistant.components.roborock] Got home data HomeData(id=3957785, name='My Home', products=[HomeDataProduct(id='41e0KOKs0d7ytUgbVg0jo', name='Dyad Pro Combo', model='roborock.wetdryvac.a83', code=None, iconurl=None, attribute=None, capability=0, category='roborock.wetdryvac', schema=[HomeDataProductSchema(id='134', name='烘干状态', code='drying_status', mode='ro', type='RAW', product_property=None, desc=None), HomeDataProductSchema(id='200', name='启停', code='start', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='201', name='状态', code='status', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='202', name='自清洁模式', code='self_clean_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='203', name='自清洁强度', code='self_clean_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='204', name='烘干强度', code='warm_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='205', name='洗地模式', code='clean_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='206', name='吸力', code='suction', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='207', name='水量', code='water_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='208', name='滚刷转速', code='brush_speed', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='209', name='电量', code='power', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='210', name='预约时间', code='countdown_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='212', name='自动自清洁', code='auto_self_clean_set', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='213', name='自动烘干', code='auto_dry', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='214', name='滤网已工作时间', code='mesh_left', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='215', name='滚刷已工作时间', code='brush_left', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='216', name='错误值', code='error', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='218', name='滤网重置', code='mesh_reset', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='219', name='滚刷重置', code='brush_reset', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='221', name='音量', code='volume_set', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='222', name='直立解锁自动运行开关', code='stand_lock_auto_run', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='223', name='自动自清洁 - 模式', code='auto_self_clean_set_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='224', name='自动烘干 - 模式', code='auto_dry_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='225', name='静音烘干时长', code='silent_dry_duration', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='226', name='勿扰模式开关', code='silent_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='227', name='勿扰开启时间', code='silent_mode_start_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='228', name='勿扰结束时间', code='silent_mode_end_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='229', name='近30天每天洗地时长', code='recent_run_time', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='230', name='洗地总时长', code='total_run_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='235', name='featureinfo', code='feature_info', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='236', name='恢复初始设置', code='recover_settings', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='237', name='烘干倒计时', code='dry_countdown', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='238', name='清洁液投放', code='set_cleanser_amount', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='10000', name='ID点数据查询', code='id_query', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10001', name='防串货', code='f_c', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10002', name='定时任务', code='schedule_task', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10003', name='语音包切换', code='snd_switch', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10004', name='语音包/OBA信息', code='snd_state', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10005', name='产品信息', code='product_info', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10006', name='隐私协议', code='privacy_info', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10007', name='OTA info', code='ota_nfo', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10101', name='rpc req', code='rpc_req', mode='wo', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10102', name='rpc resp', code='rpc_resp', mode='ro', type='STRING', product_property=None, desc=None)])], devices=[], received_devices=[], lon=None, lat=None, geo_name=None, rooms=[HomeDataRoom(id=10644633, name='room_1'), HomeDataRoom(id=10644623, name='room_2'), HomeDataRoom(id=10644622, name='room_3'), HomeDataRoom(id=10644620, name='room_4')])
2023-12-09 14:12:43.897 DEBUG (MainThread) [homeassistant.components.roborock] Integration async setup entry: {'entry_id': '6734964370b0362e9c903749a0963873', 'version': 1, 'domain': 'roborock', 'title': '[email protected]', 'data': {'username': '[email protected]', 'user_data': {'uid': 1234567, 'tokentype': '', 'token': '0000000000000000000000000000000-ttttttttttttttttttttttt==', 'rruid': 'rr66666666666666', 'region': 'eu', 'countrycode': '49', 'country': 'DE', 'nickname': 'nickname_removed', 'rriot': {'u': '8KR8bflDddB7QVA2FIx5P', 's': 'eGZCOe', 'h': 'YecIoddueN', 'k': 'rMFval9o', 'r': {'r': 'EU', 'a': 'https://api-eu.roborock.com', 'm': 'ssl://mqtt-eu-4.roborock.com:8883', 'l': 'https://wood-eu.roborock.com'}}, 'tuyaDeviceState': 0, 'avatarurl': 'https://files.roborock.com/iottest/default_avatar.png'}, 'base_url': 'https://euiot.roborock.com'}, 'options': {}, 'pref_disable_new_entities': False, 'pref_disable_polling': False, 'source': 'user', 'unique_id': '[email protected]', 'disabled_by': None}
2023-12-09 14:12:43.897 DEBUG (MainThread) [homeassistant.components.roborock] Getting home data
2023-12-09 14:12:44.013 DEBUG (MainThread) [homeassistant.components.roborock] Got home data HomeData(id=3957785, name='My Home', products=[HomeDataProduct(id='41e0KOKs0d7ytUgbVg0jo', name='Dyad Pro Combo', model='roborock.wetdryvac.a83', code=None, iconurl=None, attribute=None, capability=0, category='roborock.wetdryvac', schema=[HomeDataProductSchema(id='134', name='烘干状态', code='drying_status', mode='ro', type='RAW', product_property=None, desc=None), HomeDataProductSchema(id='200', name='启停', code='start', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='201', name='状态', code='status', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='202', name='自清洁模式', code='self_clean_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='203', name='自清洁强度', code='self_clean_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='204', name='烘干强度', code='warm_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='205', name='洗地模式', code='clean_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='206', name='吸力', code='suction', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='207', name='水量', code='water_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='208', name='滚刷转速', code='brush_speed', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='209', name='电量', code='power', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='210', name='预约时间', code='countdown_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='212', name='自动自清洁', code='auto_self_clean_set', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='213', name='自动烘干', code='auto_dry', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='214', name='滤网已工作时间', code='mesh_left', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='215', name='滚刷已工作时间', code='brush_left', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='216', name='错误值', code='error', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='218', name='滤网重置', code='mesh_reset', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='219', name='滚刷重置', code='brush_reset', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='221', name='音量', code='volume_set', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='222', name='直立解锁自动运行开关', code='stand_lock_auto_run', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='223', name='自动自清洁 - 模式', code='auto_self_clean_set_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='224', name='自动烘干 - 模式', code='auto_dry_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='225', name='静音烘干时长', code='silent_dry_duration', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='226', name='勿扰模式开关', code='silent_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='227', name='勿扰开启时间', code='silent_mode_start_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='228', name='勿扰结束时间', code='silent_mode_end_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='229', name='近30天每天洗地时长', code='recent_run_time', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='230', name='洗地总时长', code='total_run_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='235', name='featureinfo', code='feature_info', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='236', name='恢复初始设置', code='recover_settings', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='237', name='烘干倒计时', code='dry_countdown', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='238', name='清洁液投放', code='set_cleanser_amount', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='10000', name='ID点数据查询', code='id_query', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10001', name='防串货', code='f_c', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10002', name='定时任务', code='schedule_task', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10003', name='语音包切换', code='snd_switch', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10004', name='语音包/OBA信息', code='snd_state', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10005', name='产品信息', code='product_info', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10006', name='隐私协议', code='privacy_info', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10007', name='OTA info', code='ota_nfo', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10101', name='rpc req', code='rpc_req', mode='wo', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10102', name='rpc resp', code='rpc_resp', mode='ro', type='STRING', product_property=None, desc=None)])], devices=[], received_devices=[], lon=None, lat=None, geo_name=None, rooms=[HomeDataRoom(id=10644633, name='room_1'), HomeDataRoom(id=10644623, name='room_2'), HomeDataRoom(id=10644622, name='room_3'), HomeDataRoom(id=10644620, name='room_4')])
2023-12-09 14:12:54.106 DEBUG (MainThread) [homeassistant.components.roborock] Integration async setup entry: {'entry_id': '6734964370b0362e9c903749a0963873', 'version': 1, 'domain': 'roborock', 'title': '[email protected]', 'data': {'username': '[email protected]', 'user_data': {'uid': 1234567, 'tokentype': '', 'token': '0000000000000000000000000000000-ttttttttttttttttttttttt==', 'rruid': 'rr66666666666666', 'region': 'eu', 'countrycode': '49', 'country': 'DE', 'nickname': 'nickname_removed', 'rriot': {'u': '8KR8bflDddB7QVA2FIx5P', 's': 'eGZCOe', 'h': 'YecIoddueN', 'k': 'rMFval9o', 'r': {'r': 'EU', 'a': 'https://api-eu.roborock.com', 'm': 'ssl://mqtt-eu-4.roborock.com:8883', 'l': 'https://wood-eu.roborock.com'}}, 'tuyaDeviceState': 0, 'avatarurl': 'https://files.roborock.com/iottest/default_avatar.png'}, 'base_url': 'https://euiot.roborock.com'}, 'options': {}, 'pref_disable_new_entities': False, 'pref_disable_polling': False, 'source': 'user', 'unique_id': '[email protected]', 'disabled_by': None}
2023-12-09 14:12:54.107 DEBUG (MainThread) [homeassistant.components.roborock] Getting home data
2023-12-09 14:12:54.221 DEBUG (MainThread) [homeassistant.components.roborock] Got home data HomeData(id=3957785, name='My Home', products=[HomeDataProduct(id='41e0KOKs0d7ytUgbVg0jo', name='Dyad Pro Combo', model='roborock.wetdryvac.a83', code=None, iconurl=None, attribute=None, capability=0, category='roborock.wetdryvac', schema=[HomeDataProductSchema(id='134', name='烘干状态', code='drying_status', mode='ro', type='RAW', product_property=None, desc=None), HomeDataProductSchema(id='200', name='启停', code='start', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='201', name='状态', code='status', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='202', name='自清洁模式', code='self_clean_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='203', name='自清洁强度', code='self_clean_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='204', name='烘干强度', code='warm_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='205', name='洗地模式', code='clean_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='206', name='吸力', code='suction', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='207', name='水量', code='water_level', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='208', name='滚刷转速', code='brush_speed', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='209', name='电量', code='power', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='210', name='预约时间', code='countdown_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='212', name='自动自清洁', code='auto_self_clean_set', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='213', name='自动烘干', code='auto_dry', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='214', name='滤网已工作时间', code='mesh_left', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='215', name='滚刷已工作时间', code='brush_left', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='216', name='错误值', code='error', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='218', name='滤网重置', code='mesh_reset', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='219', name='滚刷重置', code='brush_reset', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='221', name='音量', code='volume_set', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='222', name='直立解锁自动运行开关', code='stand_lock_auto_run', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='223', name='自动自清洁 - 模式', code='auto_self_clean_set_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='224', name='自动烘干 - 模式', code='auto_dry_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='225', name='静音烘干时长', code='silent_dry_duration', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='226', name='勿扰模式开关', code='silent_mode', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='227', name='勿扰开启时间', code='silent_mode_start_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='228', name='勿扰结束时间', code='silent_mode_end_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='229', name='近30天每天洗地时长', code='recent_run_time', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='230', name='洗地总时长', code='total_run_time', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='235', name='featureinfo', code='feature_info', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='236', name='恢复初始设置', code='recover_settings', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='237', name='烘干倒计时', code='dry_countdown', mode='ro', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='238', name='清洁液投放', code='set_cleanser_amount', mode='rw', type='VALUE', product_property=None, desc=None), HomeDataProductSchema(id='10000', name='ID点数据查询', code='id_query', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10001', name='防串货', code='f_c', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10002', name='定时任务', code='schedule_task', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10003', name='语音包切换', code='snd_switch', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10004', name='语音包/OBA信息', code='snd_state', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10005', name='产品信息', code='product_info', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10006', name='隐私协议', code='privacy_info', mode='rw', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10007', name='OTA info', code='ota_nfo', mode='ro', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10101', name='rpc req', code='rpc_req', mode='wo', type='STRING', product_property=None, desc=None), HomeDataProductSchema(id='10102', name='rpc resp', code='rpc_resp', mode='ro', type='STRING', product_property=None, desc=None)])], devices=[], received_devices=[], lon=None, lat=None, geo_name=None, rooms=[HomeDataRoom(id=10644633, name='room_1'), HomeDataRoom(id=10644623, name='room_2'), HomeDataRoom(id=10644622, name='room_3'), HomeDataRoom(id=10644620, name='room_4')])
Would be nice to get this running
