Roborock integration clean several specific rooms
Hello, I have installed Home Assistant 2023.5.0 and added the roborock integration. Does anyone know how I can get the vacuum cleaner to vacuum a number of specific rooms such as the kitchen, living room and TV room?
I would like to fix so that I can have it vacuum these rooms with the push of a button.
Has anyone solved this?
// Chris
Hi
I use this with another app
try diff. numbers in params - start with ex.10
alias: Støvsug køkken
  - data:
      command: app_segment_clean
      params:
        - 17
    entity_id: vacuum.stovsugeren_i_stuen
    service: vacuum.send_command
So I have a solution for this that will hopefully be included in the next release.
It is possible to do yourself like the previous user said using the service, but the ids are tricky.
Roborock has a “segment_id” for each room. But to get what room corresponds with which segment id, you need,
  1. enable debug logging and find one of the first calls roborock makes where we get the user_data, you should see a rooms option, which has the name of rooms and then a 6 digit id.
  2. call the service get_room_mapping and look in the log to see the result. That maps from the 6 digit id to the segment id.
  3. Now you can use the segment ids for cleaning specific rooms
I find the roborock integration lacking compared what you can do with the hacky way of integrating it through HACS.
You can get camera there and if you spend the time to figure out the room ids you can so much more.
First of all - thanks @Lash-L for this custom integration and congrats for getting it into HA core!
I have this working as a HACS custom integration and wanted to switch over to the core integration. I just wanted to ask if there is a good way to do this? I am thinking to remove the custom integration and then add a new core integration and configuring from scratch. Thoughts?
My integration I can select any number of rooms and say clean.
@Lash-L Thanks for the step by step explanation.
I am stuck at step 1. I have enabled the debug logging. But where to find the log?
Settings, systems, logs
hey wguma,
The codes can be found in this way:
Go to Developer Tools > STATES > in the Entity field search for: camera.roborock
Scroll down until you reach the option: room_numbers:
it should be something like this:
room_numbers:
'16': null
'17': null
'18': null
'19': null
'20': null
'21': null
'22': null
'23': null
'25': null
'26': null
'27': null
'28': null
'29': null
Now you can send the robot to clean using the numbers above and find the rooms that correspond to the numbers. How?
Go to Develop Tools >SERVICES > choose UI mode >
in Service, start typing your robot’s name: Roborock: Vacuum clean segment
Target, choose your device: Roborock S8 Pro Ultra
Segment: enter the any room number and find where the robot goes
and for last, don’t forget to CALL SERVICE! :wink:
If you choose to do the above via yaml mode, replace the below with your enteties name:
service: roborock.vacuum_clean_segment
segments: 16
entity_id: vacuum.roborock_s8_pro_ultra
UI or YAML mode, they both should work.
After that is up to you to maybe create scripts and later use them to on Automations (so, you don’t need to type it everytime.
I guess that wont work for me as i have an S6 and doesn’t have a camera. But a map.
I have sensor.roborock_s6_current_clean_area and shows a number
This must not be using the core integration? I also have the s8 and do not see “Roborock: Vacuum clean segment”
@morreale & @wgumaa
I presume you both have HACS installed.
So, on HACS search and install this:
Lovelace Vacuum Map card
Once you have it installed go to any of your Dashboard and add a New Card.
Search for Custom: Vacuum Map Card
github reference: GitHub - PiotrMachowski/lovelace-xiaomi-vacuum-map-card: This card provides a user-friendly way to fully control map-based vacuums in Home Assistant. Supported brands include Xiaomi (Roborock/Viomi/Dreame/Roidmi/Valetudo/Valetudo RE), Neato, Wyze, Roomba, Ecovacs (and probably more).
On the field “Vaccum entity” add your roborock ententy name (like per picture)
Now click on “SHOW CODE EDITOR”
You should see the default config, like this:
Go back by clicking on “SHOW VISUAL EDITOR”
now click on “GENERATE ROOMS CONFIG”
once again click on Show Code Editor and you should see something like this:
Where ID 16 is a room and you just need to send your roboot there to find where it is
You can also edit it where it says “text: Room 16” and change to the room’s name.
For last, don’t forget to SAVE :wink:
I hope it helps.
Have that open ready to install. I was hoping you would verify. Thanks for the reply!
Cool beans!!! I see the room numbers!
Ok remind me now if i want to send it to a specific room what would the code look like?
hey @wgumaa,
You can use the previous instructions and you should be able to send the vaccum to where you want.
Or - You can:
Click on the button: Zone cleanup (as per picture)
Then select: Rooms
Now you can see all rooms’ name on top.
Let’s pick “Room 29” or “Room 26” as example and change their name
Go back to to Edit mode in the Vacuum Map Card
Click on the "SHOW CODE EDITOR’
Find your “Room number” - in this example I’m choosing “Room 29” - and name it as you wish.
Example:
From Room 29:
To new name: Livingroom
Once again, don’t forget to SAVE your changes.
As result, now you can tell which room number is related to their location:
I hope it helps.
Cheers :wink:
I’ve created a video with detailed instruction on how to get the Roborock Integration working. How to pick through the diagnostic information to find the room ID’s and how to create a room cleaning automation using Home Assistant as a button on the dashboard.
Hi
I have a Roborock S7 with map car wich is ok in HA (with MIIO integration and not roborock)
My problem is the button GENERATE ROOM CONFIG is grey and I can’t extract room.
Is there a solution ?
Thanks for this video - made it a little clearer than the documentation. Was able to run an automation that cleaned a specific room which is great!
Your implementation is via an automation, I’m wrote a single script to pass through a room ID as an input parameter so I can simply re-use the script and call it with an input parameter via the automation.
This only works for 1 room ID though:
alias: Robot vacuum room clean
  - service: vacuum.send_command
      params:
        - segments:
            - "{{ room_id }}"
      entity_id: vacuum.roborock_s7_maxv
icon: mdi:robot-vacuum
call via:
service: script.robot_vacuum_room_clean
  room_id: 16
Would be great to be able to call multiple rooms but I’m a HA novice and not great with the languages used in HA as of yet.
you just add the additional segments like this…
  segments:
    - 17
    - 20
    - 19
I have a script and automations so that:
when house is empty (last person leaves), the automation is triggered and it:
  1. checks where the robot is docked (as I have a dock on each floor of the house)
  2. loads the correct map for the floor
  3. runs the correct vacuum cleaning program for the floor
  4. sets a switch to say floor_1 cleaned today (so it can only run once a day)
Happy to share if interested.
