Roborock Live Map Generator
I am currently in the process of integrating my rooted Roborock S5 into Home Assistant. Because I really dislike the solutions using a server within Docker Container to display a live map in Home Assistant, I wrote a python script, which takes the map data provided by the Valetudos /api/map/latest endpoint and generates the map out of it. It lacks some polish but now does what it should.
Since Home Assistant is also Python based I was thinking if it might be worth integrating the script into the vacuum/xiaomi Home Assistant component as a sensor/camera, so that external solutions would become unnecessary? Is this viable? I had a look into the git repo of Home Assistant and I was somewhat overwhelmed, so I would need help to do that. In the meantime I leave the script here, so tell me what you think.
import io
import json
import requests
from PIL import Image, ImageDraw
import cairosvg
HOST = "192.168.1.43"  # IP of the vacuum
SCALE_FACTOR = 4 # Map scaling
CROP = False # Crop map size to content
DRAW_PATH = True
DRAW_NO_GO_AREAS = True
COLOR_FLOOR = (0, 118, 255)
COLOR_OBSTACLE_WEAK = (0, 0, 0)
COLOR_OBSTACLE_STRONG = (82, 174, 255)
COLOR_PATH = (255, 255, 255)
COLOR_NOGO_BORDER = (255, 0, 0)
COLOR_NOGO_AREA = (255, 0, 0, 128)
COLOR_BACKGROUND = (255, 0, 0, 0)
def transfrom_coords(coord, offset_from):
    coord /= 50
    coord -= offset_from
    coord *= SCALE_FACTOR
    return round(coord)
def main():
    r = requests.get("http://%s/api/map/latest" % HOST)
    json_file = json.loads(r.text)
    # map data
    dimensions = json_file["image"]["dimensions"]
    floor = json_file["image"]["pixels"]["floor"]
    obstacle_weak = json_file["image"]["pixels"]["obstacle_weak"]
    obstacle_strong = json_file["image"]["pixels"]["obstacle_strong"]
    no_go_areas = json_file["no_go_areas"]
    # robot data
    robot = json_file["robot"]
    charger = json_file["charger"]
    path = json_file["path"]["points"]
    position = json_file["image"]["position"]
    current_angle = json_file["path"]["current_angle"]
    # load image assets
    vacuum_byte_obj = io.BytesIO()
    charger_byte_obj = io.BytesIO()
    cairosvg.svg2png(url="robot-vacuum.svg", write_to=vacuum_byte_obj, scale=10)
    vacuum = Image.open(vacuum_byte_obj)
    vacuum = vacuum.rotate(360-current_angle) # correct for inverse rotation
    cairosvg.svg2png(url="flash.svg", write_to=charger_byte_obj, scale=(0.4 * SCALE_FACTOR))
    d_station = Image.open(charger_byte_obj)
    # draw map
    map = Image.new("RGBA", (dimensions["width"], dimensions["height"]), color=COLOR_BACKGROUND)
    draw = ImageDraw.Draw(map)
    max_x = 0
    max_y = 0
    min_x = dimensions["width"]
    min_y = dimensions["height"]
    for coordinate in floor:
        # store min/max coordinates for cropping
        if CROP:
            max_x = coordinate[0] if max_x < coordinate[0] else max_x
            max_y = coordinate[1] if max_y < coordinate[1] else max_y
            min_x = coordinate[0] if min_x > coordinate[0] else min_x
            min_y = coordinate[1] if min_y > coordinate[1] else min_y
        draw.point((coordinate[0],coordinate[1]), fill=COLOR_FLOOR)
    for coordinate in obstacle_weak:
        draw.point((coordinate[0],coordinate[1]), fill=COLOR_OBSTACLE_WEAK)
    for coordinate in obstacle_strong:
        draw.point((coordinate[0],coordinate[1]), fill=COLOR_OBSTACLE_STRONG)
    map = map.resize((dimensions["width"]*SCALE_FACTOR, dimensions["height"]*SCALE_FACTOR), Image.NEAREST)
    # no go zones
    if DRAW_NO_GO_AREAS:
        for no_go_area in no_go_areas:
            def draw_line (i1, i2, i3, i4):
                draw.line((transfrom_coords(no_go_area[i1], position["left"]),
                           transfrom_coords(no_go_area[i2], position["top"]),
                           transfrom_coords(no_go_area[i3], position["left"]),
                           transfrom_coords(no_go_area[i4], position["top"])),
                          fill=COLOR_NOGO_BORDER,
                          width=round(0.5 * SCALE_FACTOR))
            # draw box borders
            draw_line(0,1,2,3)
            draw_line(2,3,4,5)
            draw_line(4,5,6,7)
            draw_line(6,7,0,1)
            # create rectange on an overlay to preserve map data below; then merge it
            overlay = Image.new('RGBA', map.size, COLOR_BACKGROUND)
            draw = ImageDraw.Draw(overlay)
            draw.rectangle(((transfrom_coords(no_go_area[0], position["left"]),
                             transfrom_coords(no_go_area[1], position["top"])),
                           (transfrom_coords(no_go_area[4], position["left"]),
                            transfrom_coords(no_go_area[5], position["top"]))),
                           fill=COLOR_NOGO_AREA)
            map = Image.alpha_composite(map, overlay)
    # Vacuum cleaning path
    if DRAW_PATH and len(path) > 1:
        old_x = transfrom_coords(path[0][0], position["left"])
        old_y = transfrom_coords(path[0][1], position["top"])
        for x in range(len(path)):
            if (x == len(path)-1):
                break
            new_x = transfrom_coords(path[x + 1][0], position["left"])
            new_y = transfrom_coords(path[x + 1][1], position["top"])
            draw.line((old_x, old_y, new_x, new_y), fill=COLOR_PATH, width=round(0.25*SCALE_FACTOR))
            old_x = new_x
            old_y = new_y
    # paste docking station and vacuum; occluding items after non-occluding ones
    map.paste(d_station,
              (transfrom_coords(charger[0], position["left"]) - round(d_station.width / 2),
               transfrom_coords(charger[1], position["top"]) - round(d_station.height / 2)),
              d_station)
    vacuum.thumbnail((8*SCALE_FACTOR, 8*SCALE_FACTOR), Image.ANTIALIAS) # downscale for image quality
    map.paste(vacuum,
              (transfrom_coords(robot[0], position["left"]) - round(vacuum.width / 2),
               transfrom_coords(robot[1], position["top"]) - round(vacuum.height / 2)),
              vacuum)
    if CROP:
        map = map.crop((min_x*SCALE_FACTOR,
                        min_y*SCALE_FACTOR,
                        max_x*SCALE_FACTOR,
                        max_y*SCALE_FACTOR))
    map.save("map.png")
if __name__ == "__main__":
    main()
I dislike the docker solution either :) Is that a live-map data in valetudos /api/map/lastest ?
What is your plan to run this scripts in real-time?
I am in process of creating of creating a camera + support for it in my card (Xiaomi Vacuum Interactive Map Card). Camera part is almost done, now I work on the lovelace card
You can check out camera here:
No, that is just a reference to the vacuum robot svg, which is used to mark the position of the robot on the map. Also the generation of the map is not realtime. Every time you call the script it retrieves the data from the endpoint and generates a png of the map. If you then want an updated map you need to call the script again (which certainly can be changed).
I saw you project and I really like your card, especially the integrated zoning part :slight_smile:
But for me my current interest lies mostly on just having a camera component for Valetudo enabled Xiaomi robots (e.g. like with the consumable sensors which are already present) integrated in Home Assistant in order to have map support in Home Assistant right out of the box without the need of adding external dependencies. Not sure if your project aims for that and if it ever will ship with Home Assistant itself.
Camera I have linked above does (almost) exactly what you need, but without Valetudo.
Paths are also extracted, but they will be drawn in my lovelace card.
Hi @FriedrichNietzsche , Is Valetudos /api/map/latest stable in your environment? I’ve got “No MAP Data” too often. I’ve no idea why.
