I try to setup the Roborock Integration but after submitting my email and verification code, I get:
There was an unknown roborock exception - please check your logs.
My logs:
Logger: homeassistant.components.roborock.config_flow
Source: components/roborock/config_flow.py:106
integration: Roborock (documentation, issues)
First occurred: 8:55:19 AM (3 occurrences)
Last logged: 9:07:31 AM
Unexpected exception
File "/usr/local/lib/python3.12/site-packages/dacite/types.py", line 22, in extract_origin_collection
return collection.__extra__
AttributeError: 'types.UnionType' object has no attribute '__extra__'. Did you mean: '__str__'?
File "/usr/local/lib/python3.12/site-packages/roborock/containers.py", line 110, in from_dict
return from_dict(cls, decamelize_obj(data, ignore_keys), config=Config(cast=[Enum]))
File "/usr/local/lib/python3.12/site-packages/dacite/core.py", line 64, in from_dict
value = _build_value(type_=field_type, data=field_data, config=config)
File "/usr/local/lib/python3.12/site-packages/dacite/core.py", line 101, in _build_value
if is_subclass(type_, cast_type):
File "/usr/local/lib/python3.12/site-packages/dacite/types.py", line 168, in is_subclass
if is_generic_collection(sub_type):
File "/usr/local/lib/python3.12/site-packages/dacite/types.py", line 147, in is_generic_collection
origin = extract_origin_collection(type_)
File "/usr/local/lib/python3.12/site-packages/dacite/types.py", line 24, in extract_origin_collection
return collection.__origin__
AttributeError: 'types.UnionType' object has no attribute '__origin__'
File "/usr/src/homeassistant/homeassistant/components/roborock/config_flow.py", line 106, in async_step_code
login_data = await self._client.code_login(code)
File "/usr/local/lib/python3.12/site-packages/roborock/web_api.py", line 179, in code_login
return UserData.from_dict(user_data)
File "/usr/local/lib/python3.12/site-packages/roborock/containers.py", line 112, in from_dict
raise RoborockException("It seems like you have an outdated version of dacite.") from err
roborock.exceptions.RoborockException: It seems like you have an outdated version of dacite
I found that issue on GitHub but unfortunatly the issue is locked. It says that could be related to hacs-govee, what I have. But uninstalling it did not change the issue and using the hass-govee does Not work as it does Not find any device
