Roborock S50 v2 flashing throught Valetudo RE
I have a Xiaomi Roborock S50 v2 that I flashed a while ago.
It has the firmware version 3.3.9_001518 and Valetudo RE version 0.9.3
Some functionality from Valetudo RE don’t work (I’m thinking about the Persistent Data part for instance). I think that I should upgrade the firmware version to the latest available. I’ve seen on Valetudo RE’s Github that the latest firmware version available is 2020 with Valetudo RE version 0.9.6
I’ve also seen that in Valetudo Settings -> Info, there is a Firmware update possibility. It asks for the pkg and the pkg.md5 and supposedly it will upgrade to the firmware version from those links.
Now questions :
  1. Is it safe to do it this way? No side effects?
  2. Would I have to reconfigure everything on the vacuum? Wifi connection, timers, ssh, etc? Or will it be able to save these configurations and import them after the firmware upgrade?
Asking these questions cause I don’t want to brick my vacuum (I am not sure I would be able to unbrick it).
