Hello!
I am install “BlueStak” and older “5.0.30 Xi Home” app, with “BlueStacksTweaker5” i copy to my desktop “miio2.db” and edit with “DB Browser for SQLite” in “devicerecord” finally find TOKEN.
This token and IP address i put in my configuration.yaml restart assistant but Roborock is unavailable from Overview. Firmware on Roborock is 3.3.9_001702.
Where did I wrong!?
Did you find the problem? I have the same issue…
Problem solved by delete home-assistant_V2.db and restart hassio.After that roborock work perfectly.
