TheSmurf
(Florian Vieten)
July 4, 2023, 7:15am
1
Hey hey
I got a Roborock S8 which should clean 3 zones after I pressed a button.
Therefore I wrote a script that contains (among other things - like setting fan speed, and so on) the clean zone comnand:
service: roborock.vacuum_clean_zone
zone:
- - 39541
- 41785
- 40619
- 43311
- - 7231
- 26694
- 8931
- 27890
- - 3913
- 25266
- 7761
- 26735
repeats: 2
alias: LadenHinten VorTeichhalle saugen
entity_id: vacuum.roborockladenhinten
But with this command my roborock only cleans the first zone two times.
He ignores the other two zones.
What did I do wrong here?
poudenes
(Poudenes)
July 4, 2023, 8:41am
2
Did know this too:
This card provides a user-friendly way to fully control map-based vacuums in Home Assistant. Supported brands include Xiaomi (Roborock/Viomi/Dreame/Roidmi/Valetudo/Valetudo RE), Neato, Wyze, Roomba...
Everything you want zones, area, change settings etc.
TheSmurf
(Florian Vieten)
July 4, 2023, 10:42am
3
This card Im using.
But this doesnt help me within my script?
NathanCu
(Nathan Curtis)
July 4, 2023, 4:48pm
4
But it does…
Open the card, put it in edit mode… See that copy service call button on the editor page?
Make your selections on the vac card as you want - then click ‘copy service call’
Here in mine - I picked rooms, clicked the two rooms I want then - this is whats in my copy buffer:
"domain": "xiaomi_miio",
"service": "vacuum_clean_segment",
"serviceData": {
"segments": [
"20",
"29"
"entity_id": "vacuum.roborock_rosie"
Voila! Everything you need to paste into a script, correctly formatted for you.
TheSmurf
(Florian Vieten)
July 5, 2023, 9:58am
5
I created a testscript with different zones:
After copying the service call I get the following:
"domain": "roborock",
"service": "vacuum_clean_zone",
"serviceData": {
"zone": [
31014,
27451,
32793,
29156
28838,
27580,
30362,
29029
29734,
25017,
30745,
26978
"repeats": 2,
"entity_id": "vacuum.roborockladenhinten"
If I convert this (so that HA is happy) inside my script, I get the same as before, with the same problem:
zone:
- - 31014
- 27451
- 32793
- 29156
- - 28838
- 27580
- 30362
- 29029
- - 29734
- 25017
- 30745
- 26978
repeats: 2
TheSmurf
(Florian Vieten)
July 5, 2023, 11:43am
6
Ah everything works fine.
Im just to dumb to write 4 correct coordinates :o)
faspina
(Frank Spina)
November 27, 2023, 12:39am
7
Are you using the Roborock app, how did you get the camera entity of the map.? What HASS integration are you using.
euromem
February 25, 2024, 2:04pm
8
Hi @NathanCu which RoboRock integration are you using for the room mapping features buddy? Thank you
