Roborock skips a room
I have the problem that the living room is not cleaned with the Roborock S8 MaxV Ultra. During a routine, all selected rooms are cleaned except the living room. If I select only the living room, Roborock displays the message: “The target cannot be reached”
I am using the HACS Roborock integration & Lovelace Vacuum Map card.
Does anyone have a solution to my problem?
Thank you!
PS: It works with the Roborock app without any problems
I’m not using the map card, but have you checked the obvious thing - is the id correct, using the roborock.get_maps service?
Edit: ah, sorry, you are using HACS Roborock, not the default one. The service I mentioned above is from the default one.
I noticed that the room layout is too overlapping because the living room wall runs diagonally through the apartment. How can I change this? :upside_down_face:
Edit: It seems that the purple part at the top right is recognized as ID ‘16’. But this is the balcony, it should not be cleaned :smiley:
Edit 2: I was able to solve the problem by simply starting from scratch and reconfiguring the card. Then I just have to set up all my automations and the card again, but at least it works again :smiley:
