veli
May 20, 2022, 5:17pm
1
Roborock Vacuum entity icon icon for hass-fontawesome with dynamic xiaomi_cloud_map_extractor background image.
Icon is dynamic - takes entity state color, can be used in any entity card or header/dashboard etc.
On dark theme:
On light theme:
And “#fullcolor ” is animated!
Also made one for my dishwasher.
I will make the SVG code more legible in following days and upload here or github. Happy weekend!!
veli
July 29, 2022, 11:27pm
2
Better late than never - here is the icon with description how to get the map background: https://github.com/velijv/roborock-icon
clipse
(Marco)
December 24, 2022, 2:32pm
3
the icons look good, but could you please help me how to get them installed?
I’ve never done this before and I’m a bit lost at the moment.
Thank you
veli
December 24, 2022, 11:00pm
4
Thanks! My setup is using Hass Fontawesome :
Using with custom icons
If you have other svg icons you want to use (including but not limited to the Fontawesome Pro set), you can do so by placing the .svg
files in <Home Assistant Config>/custom_icons/
. You will need to create this directory yourself.
You can then use those icons with the fapro:
prefix. E.g. fapro:lamp
will get the icon in the file <Home Assistant Config>/custom_icons/lamp.svg
Install a font manager
Download the file to the custom font directory on your HA instance
Open the file in text editor, look at the instructions here and add your floor map as background
edit an entity, change it’s icon to: fapro:roborock#fullcolor
This can be done with any font manager plugin that supports adding custom icons i guess.
