Roborock vacuum sometimes only vacuums small area
So, some times when I start my Roborock S50 from Home Assistant it decides to only vaccum a small area (like spot cleaning). Here is an example from today:
I would of course like it to do a full clean up and not just one room. The path is free in the upper right corner and there should be no problem for it to continue. I have not seen this behavior when starting from the app, just when using Home Assistant so that’s a bit peculiar.
When starting the clean up, the robot was docked. It had not been paused, moved or anything else. Prior to docking it had done a full clean up. Have anyone else noticed this behavior? It’s the same no matter if I save the map or not.
